Question about JVC Televison & Video
Computer VGA to HDMI - JVC Televison & Video
    Sniper:
  • 52 Answers
Hi, the only way is to buy one of this Ebay Items, they are converters/box, that need to change the analogical signal to digital signal, a single cable won't work.
Posted on Oct 16, 2013
I have HDMI laptop and Dell 1706FPVT 17" VGA monitor. I have VGA to HDMI cable and I connected the cable between these two machines but it is not working. Solution, please.
First of, a little bit of explanation.
VGA = analogue
HDMI = digital
The answer seems to be in your question.
it reads "VGA to HDMI". These cables or adapters doesn't work the other way around. I am guessing your cable can only support vga output to HDMI input. And your setup is HDMI output from your computer to vga input to your monitor.
Solution:
Try and find HDMI to VGA cable or adapter. This is expensive.
If your computer has a vga output, use this with vga to vga. You won't get a better resolution by using HDMI to vga.
Or are you stuck with only HDMI output?
There are adapters for USB to VGA too. This could be less expensive. I have one for my friends Apple Air. I am not a "i" fan so I do not have much experience on Apple.
Hope this helps.
May 04, 2014 | Dell 1706FPVT 17" LCD Monitor
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
Connect aspire v5-552p to tv
It depends on the ports the computer and the TV have
If both have VGA (blue) use a VGA to VGA cable.
You can also use an S-Video-to-S-Video cable
If both have DVI, use a DVI-toDVI cable.
If both have HDMI use an HDMI-to-HDMI cable.
Other possibilities are combinations of the various modes above VGA-to-DVI, VGA-to-HDMI, VGA-to-S-Video, etc.
VGA-To-D
Nov 07, 2013 | Acer Aspire Computers & Internet
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DFid something, In my CPU i dont have the slot for the other type DFi, ...
I believe you are referring to a DVi connector. We have different types of connectors but none of them is DFi. We have VGA, HDMI, SATA, and DVi connectors. Here's a cheklist of what you need to do:
  1. Check the connector of the computer whether you have VGA, HDMI, SATA, or DVi
  2. Check the connector of the monitor whether you have VGA, HDMI, SATA, or DVi
  3. Now that you know the type of connectors you have for your system, you know what cable to buy.
It does not really matter if your computer and monitor have different connectors. We can purchase cables with VGA - VGA, HDMI - HDMI, DVi - DVi, VGA - HDMI, VGA - DVi, HDMI - DVi. So, don't worry and thank you for choosing FixYa!
Feb 21, 2011 | Acer X193W LCD Monitor
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
Dec 10, 2010 | Televison & Video
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
