Question about Whirlpool 24 in. DU915PWP Built-in Dishwasher
Whirlpool dishwasher adp4407 wont start
Hi
My 14 month dishwasher (whirlpool adp4407) wont come on. Seems to have no power- Have changed plug and socket and fuse to no avail. Still water in bottom of it but drainage pipe seems ok. Anyone got any ideas?
mark
  • 113 Answers
Be sure the door is shutting properly the door switch may also be bad
Posted on Apr 24, 2009
I have a Whirlpool GU2455XTS dishwasher that has a problem with the rinse aid dispenser. It appears to be plugged. How do I unclog this. Do I have to remove front panel to access it. Any help will be...
How do you know it is "plugged". I have a GU2455XTSS2 which has a rinse aid dispenser which always reads "full" & afters months of use it's still "full". Other than this it seems to work OK.
Aug 29, 2011 | Whirlpool GU2455XTS Built-in Dishwasher
The start light is flashing on and off and the programmer wont change to another programme it stays on the normal programme and the dishwasher will not start
Seems to be relatively common. Ma doing one now with that exact problem. If you hold button in for about 10 seconds, it should reset.(switch off then on again to push start.). If same action continues, the electronic module needs to be replaced.
Dec 31, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
My unit used to send steam out of the top but no longer gets hot. I'm sure the coil should be replaced. This unit was pricey and is used every 7-10 days over the last 14 or so months. My last unit lasted...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 07, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher wont turn on when start is pressed. It wont fill. We have checked all connections and it is plugged in. We got it to work about 5 times by using the reset code but it never would start to...
It seems that the control board is faulty as there is no reponse to the panel even with all checks. So if the power seems right , ther fault can be the program controller.
Please check the motor wiring, the pump and connections once again before the board can be changed.
Sep 28, 2010 | Dishwashers
My dishwasher wont change cycles.
its might be your heating element or the thermostat check if the heating element get hot if not theres your problem...
the machine try to get to sertion temperture and cant do that so it stuck in the same mode...
heater # 8572861 coast 20-30$
Thermostat Number: 661566 = 14$
hop it helps
Jan 22, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Not Working at All
Check wire nutted connections where power cord connects underneath.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
DU1100 XTPS DIshwasher
I would make sure that the lever on the dishwasher body is not bent in any way. If it is you can straighten it out and then make sure the door close's properly. But for being 3 months old I would give whirlpool a call and have them send a repairman out. There will be no charge to you seeing its under there warrenty.
Jul 21, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
397 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
