Question about Welding Tools
Clarke turbo weld 100en mig welder will work somtimes then it starts to hum and it wont weld
1) Unplug, take off the cover and check the inside power connections 2) Check the contact point for on/off
Posted on Oct 18, 2013
3 Suggested Answers
  • 23 Answers
SOURCE: Do you have any info
goggle it
Posted on Dec 17, 2010
langman_kevi
  • 3 Answers
SOURCE: I bought a used Clarke Turbo Weld 150 EN mig welder, but I didn't get an owner's manual with it. Where can I find a manual for this welder?
Follow this Link:
http://www.clarkeservice.co.uk/manuals/mig_welders/migpro90_150te.pdf
Let us know if it was the right one.
Posted on Mar 02, 2012
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
Clarke pro 90 gas mig welder wont penetrate
I have the same problem, please that´s some one knows how to fix this?
Apr 19, 2010 | Clarke Power Products WE6480 MIG95 Flux...
Can i weld 1/4 steel with my clarke 100en
yes but it is going to take time and patience,if possible you need to grind a v groove in the two pieces your going to weld ,it is going to take several passes to fill in groove for the penatration of the weld.
Mar 25, 2010 | Welding Tools
Welder hums when you turn it on but it still welds. Sounds like a 3-phase motor with a dead leg. Ever setting is the same.
ive got a crapsman mig welder that does the same thing, i took it apart and the transformer looks to be fine, probably bad news in the long run
Apr 12, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
Mar 24, 2009 | Welding Tools
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Oct 29, 2008 | Clarke Power Products Welding Tools
Welding Tools Logo
81 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
