Question about Dell Dimension 4700 PC Desktop
New sata hdd seek failure
I installed a new 320GB WD sata drive in my dell 4700 and it says drive seek failure. My old drive was corrupted and through all my troubleshooting this was the solution I came up with. I couldnt get ionto the OS before and kept gettin blue screen.Any help is appreciated.
  • 10 more comments
  • jcorreiacv Apr 24, 2009
    yes it,s a desktop. I try it on the default setting which is no jumper. tried different jumper settings and still nothing. I can see the drive in the setup utility but it gives me two beeps when I boot and says seek failure.
    everything in the pc is as it came except for the new HDD. does the BIOS have anything to do with it?
    Sounds good because it should work right off the bat no problems. Thanks for the help guys. this is my first time on this sight and I like it. It's on my favorites list.
    yea you know how technology is. Im takin it back now.
    yes it was a maxtor 80GB SATA. I was getting a blue screen error and PC wouln't boot at all. So came the new HDD option. Installed and it says diskette drive 0 seek failure.New one is in and still getting same error. I need help.
    no floppy. all floppy drives are disabled and USB drives are enabled but I don't have one.
    hdd is 1st boot and cdrom is 2nd
  • jcorreiacv Apr 25, 2009
    Ill try and see what happens thanks
    its seen in the bios but no boot device available
    finally got it to work on SATA 2 appreciate all the help. see ya sooon
  • geraldo14200
    geraldo14200 May 11, 2010
    I assume this is in a desktop computer yes? did you make sure you set the pin on the back of the drive to MASTER?
  • 123 Answers
If you dont have a floppy drive is it disabled in bios.
Are you sure your power supply is powerful enough?
If none of the above then return the hdd - its faulty
Posted on Apr 24, 2009
  • 7 more comments
  • Fritzelly Apr 24, 2009
    There is no master or slave with sata drives! Ignore the jumpers
    In fact you should take it off unless you need backward compatibility
    Its a new HDD, when you put it in its telling you its having problems reading the disk.
    Take it back to the shop
    No problem, sometimes HDD's just dont work
    Just thinking - was the old drive a SATA?
    Ok you left before my comment.
    You didnt answer about the floppy drive, go into your bios and disable the floppy drive if you dont have one.
    If you do have a floppy drive make sure there isnt a floppy in it,
    Change boot order in bios so your hdd is first.
  • Fritzelly Apr 25, 2009
    You probably have 2 sata connectors on the board (at least) - try the other connector
    In bios check the drive is configured to sata and not ide - unless you specifically want it to act like ide
    I have to go but will be back tomorrow if not solved.
    Just to be sure you have connected the power cable to it as well...
Bought a dimension 4700 at the local goodwill and am having trouble getting it working
It sounds to me like the on-board HDD controllers are dead. Have a look at the motherboard... I'll wager you'll see a fried capacitor right in the middle. Common Dell failure :(
Jul 20, 2014 | Dell Dimension 4700 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
I need the drivers a western digital sata 160 g hard drive model wd1600aabb for the xp platform please!!! can anyone help?
There are no such drivers....sata hard drives use windows drivers...if the computer is asking for drivers for a hard drive, then it is seeking drivers within windows...which means there could be corruption in those windows drivers that the WD HDD needs. Try going to windows update, let it load and check for updates and instead of hitting express, hit custom and look in the left hand pane for hardware updates and see if the drivers for a hard drive would be there. WD only offers Firmware updates and software for its HDD's.
Sep 04, 2009 | Western Digital Caviar SE WD1600AAJS 160...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
How to replace HDD in Mybook 320GB
Yes you can use anyones SATA but it will have to be formatted properly for the MyBook320.
Jun 15, 2009 | Computers & Internet
Presario Media Center new SATA 320GB WD
Check to make sure you used a SATA hdd & not a SATA II hdd for your replacement. Usually these are not backwards compatible. Hope this helps.
Jan 10, 2009 | Compaq Computers & Internet
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Installing new HDD & another DVD drive
Comment by agimqose, posted on Jan 04, 2008 Ce qualcuno che mi aiuti nel mio problemo di hdd maxtor diamondmax 16,,,160gb?...Ho formatato voglio un nuovo boot software per dvd rec jvc drmh30s,ma perche mio hdd e corrupt.che procedura?che software per mio hdd?...mille grazia a tutti. agimqosesda@yahoo.com
Dec 24, 2007 | JVC DR-MH30S DVD Recorder
Dell Dimension 4700 PC Desktop Logo
236 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
