Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
Welder works sometimes then it hums and wont spark
  • 79 Answers
Your rectifier is going bad.
Posted on Oct 18, 2013
Repair mig welder
Control circuit failure or blown fuse on low voltage power supply. Look for 24VAC transformer. If that is OK follow to the trigger contactor and see if it is disconnected, burnt, etc.
Aug 28, 2014 | Welding Tools
My lincoln mig 140 feeds the flux wire through, but it just sparks, will not weld
Make sure the ground clamp has a good connection to both the work piece and to the welder Sometimes the welder connection is overlooked.
Jan 13, 2014 | Lincoln Welding Tools
Clarke turbo weld 100en mig welder will work somtimes then it starts to hum and it wont weld
1) Unplug, take off the cover and check the inside power connections 2) Check the contact point for on/off
Oct 15, 2013 | Welding Tools
Hi I have a Lincoln Handy Mig I am running 0.30 wire welding a roll cage on a race car the welder keeps overheating {light keeps coming on} wont weld just sputters keeps kicking the breaker {20 amp}...
check to see if the cooling fan is working. put a box fan behind the welder so it will blow threw the vents on the rear, or better yet remove the side cover and let the fan blow into the side of the welder.if this works replace the cooling can......GOOD LUCK
Jan 29, 2011 | Lincoln Welding Tools
Welder wont strike and keep an ark
Check the output voltage of the welder (the torch and earth clamp). The voltage should be around 30 to 40 volts. If yu see the normal spark from the rod as you strike, but cannot hold an arc, have a look at your rods, they could be old, damp or incorrect for your welder or the type of work you are attempting.
Jan 19, 2011 | Hobart Welding Tools
How would one attain a replacement for the main circuit board
The main control circuit for the welder has gone bad....cost about $198.
Might be better off to buy a new welder.
Feb 03, 2010 | Hobart Handler 140 Mig Welder
Welder always pulsates and doesnt feed wire at a steady speed. There is also a humm sound when you turn it on also sometimes it doesnt work at all
Most welders hum when turned on. The pulsation could be the unsteady feed. The feed could be one of several things. The rollers that drive the wire could be adjusted too loose. The tip could be damaged/burnt/melted. The tube that the wire feeds through inside the lead could be damaged or kinked. Be careful when welding that you don't have the lead bent too much -- keep it as straight as possible. This will minimize problems due to kinking. When you say it doesn't work at all, if you mean doesn't feed, this could be the same problem. If it doesn't turn on at all, that's something else. Post more details and we'll see what we can do.
Nov 27, 2009 | Clarke Power Products Clarke 130EN...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Wont spark or weld
lets go over the basics 1 do you have it set up ,the wire feader turned up at least to see if it sparks 2 do you have itset up at least to see if the amps are on enough to get a spark? try thoughs and see where you are,then turn those up enough to weld with . (make sure your wearing a good helmut .please you only get one pair of eyes!!!!!!!!! )hope this helps jojogunn.
Mar 13, 2009 | Hobart Handler 125 Ez
Have a Millermatic 200 wire welder! s/n:JJ048290!
the problem is your project is not grounded, attach the grounding cable from your welder to your project your welding.
Jan 26, 2009 | Welding Tools
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
85 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
