Question about Whirlpool LEW0050P Electric Dryer
The blower is not coming on? - Whirlpool LEW0050P Electric Dryer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 156 Answers
Sounds like the blower motor needs replaced...... Although if its a matter of no heat then you can change the heating element inside the dryer fairly easily
Posted on Oct 15, 2013
My Rheem Criterion II gas furnace makes metal slapping noise when the blower comes on. It is not the blower or the motor.
Is there noise when the inducer motor comes on? The small motor that comes on first. It sucks the co out of the combustion chamber. It comes on first. Then the burner lights then the blower comes on. And the noise continues while it's running and doesn't stop till the blower stops? Is that correct? But it's not the blower wheel? Could it be out of balance and hitting the blower shroud?
Feb 18, 2017 | Heating & Cooling
Blower motor resistor
The blower motor is located under the passenger side of the dash. there should be power on the dark green wire at the blower motor. If there is no power check the 40 amp blower fuse and the blower relay. If there is power than ground the light green with white wire with the blower motor plugged in. If the blower does not come on than the blower is bad. If the blower comes on than you have a ground issue. The system is ground side controlled which means the switch provides ground. If the blower does not work on high I would suspect the ground wire is burnt on the backside of the switch since high speed bypasses the resistor.
Apr 30, 2013 | 2000 Dodge Durango
The AO code came up when I tried to start the heater today. What does that mean?
Is the blower coming on? If not, i would start with the blower. You would need to check for voltage going into the blower. If you do, and blower is not coming on, then the blower is bad. IF the blower is on, then check the tubing coming to/from the blower for breaks or disconnected. Also, may be a bad blower vacuum switch. You can jump this after a call for heat has been established to see if it fires. You should only attempt this if the blower is working.
Apr 26, 2010 | Hayward H Series
Blower cuts off when compressor comes on. Blower
Try the fan"on/auto"function switch at the thermostat when the compressor is on.Set fan to on.Does blower run?
Mar 19, 2010 | Coleman Heating & Cooling
I have a 2000 sportage. The heater fan does not
It may be the blower motor, or it may be the blower resistor. Check for power at the blower motor. If power present with system on and blower has good ground, motor bad. If no power check blower resistor in air box prior to blower motor. If power on input side but nothing coming out to blower change resistor.
Jan 30, 2010 | 2000 Kia Sportage
Front blower motor stoppeed workin, replaced teh relay and fuse in the fuse block. Still have nothin
you wont till you replace the blower motor it self i owned a few of them and the blower motors do go out without any notice
Jan 15, 2010 | 2005 Dodge Grand Caravan
My heater blower dont come on when it real cold in the mornings but will come on later in the day
When the blower motor does not want to come on,reach down and bump it,and see if the blower comes on,if it does,replace the blower motor.
Oct 23, 2009 | 1994 Chevrolet S-10
Blower quits intermediately and the driving lights go out
you need to follow your wires from the blower motor and either rewire it or run a new wire to the blower or heater
May 31, 2009 | 2001 Pontiac Grand Prix
02' LIBERTY BLOWER MOTOTR COMES ON WHEN IT WANTS TO.
Sound like a weak blower motor to me
Dec 12, 2008 | Jeep 10 x 20
Whirlpool LEW0050P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
