Splendide ariston tvm63x There is a thermostat at the front of the machine in the filter area. What temperature does this thermostat control the circulating air to?
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Cleaning the filter
Clean or replace the filter - check manual or Tech support for this machine.
Posted on May 17, 2007
joboo1
  • 257 Answers
SOURCE: Heating circuit and thermostat design
Hi, You need a thermostat with a remote sensor that should be about the same position as the middle rack in the cabinet. Yes, have the circulating fan run constantly on a separate switch or on a rotary in the second position and the fan/heater in the third position as off, fan on, fan/heater on. I would also wire in an indicator light or two as well as some way to monitor temp/humidity so that you would have a positive indication that things were running, the idea being so that you open the cabinet as little as possible. By the way this works great for fruit with just the fan. Good Luck!
Posted on Feb 11, 2009
  • 42927 Answers
SOURCE: no heat comes on my dryer Ariston Model # TVM63X while trying to dry. All I get is cold air while it is running
Heating element failure
Posted on Mar 18, 2017
Where is the high level thermostat located in the Ariston TVM63X dryer?
Feb 23, 2018 | Dryers
Why won't my Splendid Ariston washer spin during a regular wash cycle?
Remove the kick plate from the front of the machine and you will find a removable screw-in bung. Put something underneath to catch water. When you remove it, you will find a plastic toothpick in there which is jamming the pump impeller. The safety feature stops the machine spinning if the pump is not working.
Splendid Ariston Google Search
Jan 03, 2017 | Washing Machines
New tvm63x splendide. Dryer stops and restarts during drying cycle. What could be causing this? Thanks.
Check for a lint build up in the vent hose. Too much will trigger a sensor in the dryer to shut off to prevent a fire.
Nov 19, 2014 | Splendide Washing Machines
Where to finde front door handle
This is the information taken from the Splendide website. Hope it helps.
Westland Sales - Splendide Service Headquarters in Clackamas, OR Telephone:
Direct Fax:
E-mail:
Hours: 1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
*To help us serve you better, please have the Model & Serial Number of your machine ready when you call. The Serial Number is located on the inside door opening of your machine.
Jul 26, 2014 | Ariston Technologies AWD 121
How to fix error code f 05 on splendide arwxf129w (na)
F05: Blocked Pump or Pressure Switch stuck on Empty Found
Overhaul CNF (pump connector)
Overhaul Pump Connector
Control Pump Filter
Control Pump Windings
Change Pump
Replace Card
Dado
Jun 07, 2014 | Ariston Technologies Washing Machines
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
