Question about Tefal GV7070 Iron
Clean distilled How to clean limescale tefal gv7070
  • 2,113 Answers
Use CLR or any other lime scale remover you can find. Pour out any water in the bottom chamber and put some CLR into it. leave it for 10 minutes to an hour. Run it to have some CLR so though any passages, then pour out any remaining CLR and replace with water again to wash out the CLR. When you are satisfied that the CLR is all rinsed and replaced with clean water, then it is safe to iron again. CLR can alway be put on a cloth and wipe the iron surface or any deposits.
Posted on Oct 16, 2013
Remove algae from GV7070 water tank
Chlorine/bleach - read carefull the instruktion on the back og the bottle. DO NOT USE IT without thinning it with water in the correct dosis! Let it rest til everything is dead. Dont get it in the machine it will be damaged. Do not boil it in the machine! only for use in the watertank. Clean carefully.
May 21, 2014 | Tefal GV7070 Iron
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
How to clean lime scale out of iron tank
All you need for this is a cotton cloth and white vinegar, a small amount. And you have to rub with cotton cloth for the limescale. Vinegar will act and the limescale will disappear from here.
If it doesn't help you can mix the vinegar with baking soda and it will be a good start point.
When you have finished to polish and to clean the outside, you can clean your iron from inside. For this you have to put a small amount of vinegar and you have to mix it with water.
You have to switch it on to wait. And press the steam. All the limescale will come out of there.
You see? And your iron is shiny and clean, from inside and from outside as well. .
May 19, 2011 | Tefal Irons
The iron is not steaming
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 04, 2010 | Tefal GV7070 Iron
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Sep 28, 2009 | Rowenta Powerglide DE011 Iron with Auto...
LIMESCALE BUILD UP
To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
May 12, 2009 | Irons
Tefal GV7070 Iron Logo
144 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
