Question about Bluedio Model R - Wireless & Bluetooth Noise Cancelling Headphones
How do I reset my Bluedio R headset to factory specs.
How to factory reset my BLUEDIO T2?..help me pls..
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
Sep 16, 2016 | Cell Phones
How to reset bluedio turbine h+?
I'm with the same problem. Dpes anyone know how tp factory reset bluedio turbine h+?
Aug 05, 2015 | Bluedio H Turbine Bluetooth Headphones...
Bluedio bluetooth service center in Bangalore
I purchased Bluedio I4 bluetooth headset a month ago and as I was out of town for a month the device was received by my mom and it was not unpacked. I unboxed it today and after putting to charge for 4 hrs I took of the charger and tried to turn on the bluetooth by pressing the call button but it does not turn on. However it works only when it is plugged to the charger? What could be the problem? Have I screwed the device or is it a device problem?
Regards,
Sajith.
mail - v.sajith1988@gmail.com
Feb 21, 2015 | Radio Communications
I have a bluedio wireless headset model DF610. It is connected to my phone, but there is no sound, even with the volume turned up. Can the headset be reset? if so, how?
The only way to reset something like this is to remove batteries for a bit. Once all capacitance charge is spent, probably 30 seconds at most, units will be at factory settings. I doubt that this will work on a headset, but it is all I got. Take the headset back for warranty.
Oct 26, 2014 | Radio Communications
How can i turn on my bluedio E9
very simple....jst hold the on button(continuesly) then search for de device.....when it shows up press conect den press 0000 for de pair code...thats all and any thing u see jst press yes!!!.
Feb 09, 2013 | BestOfferBuy Bluedio H9 Bluetooth Micro...
My nokia 5800 can't find the bluedio AV890!!!!
may be due to the difference in blue tooth standards. if this then not any chance of connectivity.
Jun 29, 2011 | Nokia Lands Phones
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V (muthupetchi008@gmail.com)
Apr 15, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Apr 13, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Bluedio Model R - Wireless & Bluetooth Noise Cancelling Headphones Logo
899 people viewed this question
Top Bluedio Audio Players & Recorders Experts
Vernon Taylor
Mark Cheong
Mark Cheong
Are you a Bluedio Audio Player and Recorder Expert? Answer questions, earn points and help others
