Question about Smeg WDI12 Front Load Washer / Dryer
On my washing machine there is a reading of E-02 what does this mean?
    Master:
  • 492 Answers
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Posted on Oct 15, 2013
Washing machine wont spin f-02
The Hotpoint F-02 error code is associated with a Motor Fault, now strange as this may sound, but it possibly wont mean the motor is faulty, it simply means the main PCB in the machine has sent a signal for the motor to start, but it's not receiving one back to say it is going.. Usually if you can turn the drum by hand, then the fault would generally be the Tacho of the motor, this is a small device on the back of the motor with two wires coming from it. Check to make sure the Tacho hasn't come loose or fallen off, then one by one remome and reattach the connectors going to the main PCB, vibration can cause these to become loose...Good Luck
Jun 26, 2014 | Hotpoint Washing Machines
What does f 02 mean?
Sorry to read about your problem, I hope this helps you out.
you have a drain clog issue either hose or pump
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Whirlpool GHW9200L Front Load Washer
02 error what does this mean?
Hi There
I hope you had a good x-mass this year. I have the codes for you so you can read them.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Than you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | LG Washing Machines
MY WASHING MACHINE STARTS A WASH CYCLE THEN SUDDENLY STOP AND STARTS FLASHING F-02 WHAT DOES THIS MEAN?
Hi.
Error code F02 is a problem related to the motor.
It means that the motor is jammed, or tachco detached.
Check connections on motor and module, and motor plug.
Please rate my solution.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Front load machine getting F 02 flashing on screen machine has stopped working??? Help
That code means the aquastop has activated. This means that you have a leak on the machine which is filling the tray underneath with water and stopping the machine from working. Probably a job for an engineer.
Jun 07, 2009 | Whirlpool Washing Machines
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool wm 1000 semi pro washing machine
if you can give a more complete mod # i can help you on the front loaders its a slow drain time the mod # you gave me dont come up look on the lid or the back of the control panel for ser plate http://www.whirlpool.com/custserv/index.jsp try here for manual
Dec 28, 2007 | Washing Machines
Whirlpool duet ht. pops code f 2
f-02 means long drain. remove panel below door. pump will be in center right in front of you. remove cap and clean out pump. unplug washer first ofcourse
Nov 17, 2007 | Washing Machines
Smeg WDI12 Front Load Washer / Dryer Logo
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Owen Barnes
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
