Question about Linksys Wireless-G WRT54G Router
Need to reconfigure Linksys Wireless Router
I recently changed from AT&T DSL to Sprint Wireless. My Wireless Modem connects my computer WiFi to the router, and the and my Lexmark WiFi is connected to the router also. But when I try to print, the printer sends a "difficulty connecting to the printer. My Linksys CD is apparently damaged. I tried to connect to the IP address listed in the manual (http:// 192.168.1.1./) and get unable to connect message with your website listed.
I have tried connecting the printer and my laptop both through the Sprint Wireless Modem and through the Windows Network connections with no luck.
I am not a network whiz, but I can follow instructions if they are detailed.
Jim Gallagher
  • JGallag Apr 24, 2009
    I don't have time right now to work on this, but have saved th URL and will let you know what happens. Thanks for the quick response.
    Scholar:
  • 132 Answers
Jim,
There are a few steps that we can try. If you want to email me at doingitright@blueskyit.ca for further instruction then that's fine. Try the following first:
I will assume you have Windows XP:
1. Click Start button.
2. Click Run.
3. Type in cmd and then hit enter.
4. Type in ipconfig /flushdns and hit enter.
5. Type in ipconfig and hit enter. This should show you a few IP addresses.
6. If you are connecting to the router okay, you should see a gateway address listed. Write that down. Keep the command window open for now.
7. Go to your desktop and open a browser window. Type in the gateway IP address. This should bring up a sign on to the Linksys. If it doesn't, then there's an issue between your PC and the router.
8. Assuming it does bring up the Linksys then sign on to it. Look for an area that will show you devices connected to the router. Do you see the printer? It may show you a MAC address for the computer and the printer with IP address beside it. It may be located under the wireless area.
9. If it does show printer info then write down the IP address. If it doesn't show info then it's possible that the printer isn't configured properly.
10. Log out of the router window.
11. Bring up the command prompt again and try pinging the IP address of the printer (if you have it from the router). If it replies then you should reboot your computer and try printing again. If it doesn't reply then chances are the printer itself isn't installed on the right port.
12. You can check port connection on the printer by going to your printer folder, look at the properties and see what port it's using....for example: if you had it using USB prior to wireless then you want to change it to use the IP address.
There are a few more steps to try but it depends on what happens to this point. Another thing to check is on the printer device itself - go into the network setup which should be under the settings menu somewhere...sorry not sure of the Lexmark model you have. Make sure that the IP address info is listing properly. You can try printing a config page directly from the device as well to show you what IP its using....
Let me know if there's anything further required. If you email me directly then I can continue to help, otherwise someone else may grab this issue to assist further.
Thanks.
Posted on Apr 24, 2009
Went from wildblue internet service to dsl and need to know how reconfigure linksey router
Wildblue is DSL Internet service provider.
You can change the Internet connection settings of Linksys E3000 manually.
Or you can simply reset the router and reconfigure it by running the CD.
See How to setup Linksys E3000
Oct 17, 2011 | Linksys E3000 Wireless Router
I recently changed my internet service from cable company suppplied to At&T DSl service. How do I reconfigure my wireless rrouter to accpet DSL service. I have a Linksys WRT54G wireless router. Thanks
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2010 | Computers & Internet
Router communication with cable modem
If you change service providers, connection type and hardware, then all your previous connection settings will not work, and they'll have to all be reconfigured.
Have you been given a new modem/router (combo unit)?
Did you previously have a separate modem and a separate router?
Do you connect your xbox via WiFi?
Go back to basics now. If your computers connect fine, then connect the xbox using an ethernet cable and see if it works. Then try wireless.
Feb 27, 2010 | Belkin (F5D7230-4) Router (587009)
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Is there other way to recover my old password
You dont have to reconfigure if all you did was change to dsl.
Unplug dsl modem. Unplug router. Turn off computer.
Wait at least 30 seconds, plug in dsl modem.
Wait at least 2 minutes, plug in router.
Reboot computer. All should be OK. If not, reply back, and I'll helo you further.
Feb 01, 2009 | Zyxel ZyAIR G-302 (760559111205) 802.11g/b...
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
149 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
