I have an old Samsung CRT TV model TXM3296HFX. Picture still looks great. But I wish I could expand the image to fill the whole screen. There's about an inch on both sides that appear are not getting used. Is there a way to stretch or adjust the picture all the way to the edges?
    Top Expert:
  • Televison & ... Master
  • 74,844 Answers
It sounds that the output voltage comes out from the SMPS is lesser than normal. Check it. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 16, 2013
  • Chano Equis
    Chano Equis Oct 17, 2013
    Thank you so much for taking the time to respond. It's totally watchable and I think most would not notice. Truth is, I just got this unit (for free-amazing) and I don't know how it performed prior. I wonder if it's also possible that it came this way from factory. I'm not technical enough to check that voltage. Was hoping there was some dial that could be uncovered that a simpleton could turn!
  • Chano Equis
    Chano Equis Oct 21, 2013
    Hi Sasi, well your post did inspire me to dig more. So I located the serivce mode screen! After looking at those settings and taking a closer look, it looks like the screen is normal. When the TV is off, the material that makes up the screen which is gray in color, also has the same visible black "margin". Thanks so much for reaching out. The way to get to the service screen for anyone looking up this type of unit is: Power Off>Mute>1 8 2> Power On
  • 275 Answers
SOURCE: Edges of Picture & Text Sloping
I agree with techman.Looks like a dry solder or overheating in the Pion cushion correction ckts. Beast let a pro technician take a look. Nothing much u can do. Pravin
Posted on Jun 26, 2006
techman
  • 3130 Answers
SOURCE: Picture on TV is Cut Off
Emmi I am sorry you have been having problems finding the service manual as you are correct, you cannot go to www.samsung.com and find it, but you can simply go to http://samsungparts.com/ and find it! I already did the work for you my freind and found the manual for you at this link http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=SM-TXJ3678&search%5Fmodel=TXJ3678 Hope this helps. Good Luck
Posted on Mar 21, 2007
SOURCE: Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Posted on Oct 23, 2008
jo_chinmay
  • 143 Answers
SOURCE: Connecting Dell Precision Laptop to Samsung 29 inch Easy View (CRT) T.V
dear sir.
here u have to chek cable yr laptop is not support with a same s-cable u need to connecter for s-vadio to audio vedio connector and it's convort yr s-cable to comosite cable afer that it's automaticly dosply thru composet.... yeah one thing have to chek with different cable then selacet display propatise to set output setting is set in to s-video.. it's help u...:)
Thanks
please vote
jo_chinmay
Posted on Jan 02, 2009
chanddra2009
  • 615 Answers
SOURCE: how to connect dell laptop to samsung 29 inch tv using cable
Dear Sir,
For getting display in TV you have to select input source as TV generally in all other laptop
short cut key is fn+f4. generally short cut function key shows picture of small square box.Search for that short key then activate the out put for TV by pressing that key with Fn keys.
I think it solves your problem.
good luck
Posted on Aug 27, 2009
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
My picture fills the whole screen to the point people look distorted
Look on your TV remote. Look for a button that reads "Aspect". While watching TV push the Aspect button until the picture is they way you want it.
Sep 01, 2014 | Samsung La32d400 32" Hd Lcd Wide Screen Tv...
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Full picture not in screen
Sounds as though you have a leaking Capacitor in the horizontal section. The problem capacitor is likey to be orage in color and rated at 2kv or higher. Located next to the High Voltage transformer ( Flyback transformer ). Be very cautious if you are changing this, or any part yourself as the picture tube can charge high voltage ( up to 35,000 volts ) for a long period of time. Always discharge the picture tube first before servicing a set.
Replace the capacitor with a like part with the same or higher voltage rating and the same capacitance number ( mfd, pfc,or such ) as listed on the side of the part.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 12, 2007 | NetTV DTV34XF3 34" TV
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
SAMSUNG 42inch HC-P4241W MODEL CRT AGING
explain what the picture looks like? Does it look like the edges are in 3-D?
Jul 25, 2007 | Samsung HC-P4241W 42" Rear Projection...
TV picture was warped, no it is black, but the power light remains on...
the problem you are having is in the power supply you can go ahead and take your set to a repairman o look at your set good luck.
May 02, 2007 | Philips Magnavox MS3652S 36" TV
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
