Question about Garden
My electric Campbell hausfeld 1750 psi won,t always start when I pull the trigger .sometimes it will quit while running. the motor and pump seem to be free. it works good while it is running. CR
  • 47 Answers
Hi , i'm not familiar with the machine so without model numbers it is hard to diagnose.
if it is a trapped pressure unloader valve, ie the motor turns off when you let go of the trigger , then it is possible for it to be a pressure switch causing problems. the pressure switch may turn it off immediately you let go of the trigger or it may have a delay stop on it, where it will turn it off after a predetermined time interval. it is quite common for springs to break or microswitches to fail in these switches.
Posted on Oct 16, 2013
4 Suggested Answers
  • 770 Answers
SOURCE: My 1750 psi campbell hausfeld pressure washer will
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Posted on Oct 19, 2009
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
I need to separate the pump from the 5.5hp gas engine
usually held in place by 4 alen key or hex bolts. sometimes very difficult toslide appart.
be sure to meassure shaft size as they are usually different size on each motor size graduation.
Aug 22, 2013 | Campbell Hausfeld Pressure Washer Gun -...
Motor quits when pull trigger
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Jul 13, 2013 | Campbell Hausfeld PW2102 Gas Pressure...
Gun
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
My 1750 psi campbell hausfeld pressure washer will operate at first until I release the trigger on the wand. Then it won't restart. If I wait for a while it will run again. Sounds like the pressure switch.
Oct 18, 2009 | Garden
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Campbell Hausfeld 1750 Pressure Washer Won't Start
throw it away seems to be the only solution since no one has a clue in what there talking about, nothing froze always cleaned out system and still wont start, campbell hausfeld does not have a clue neither, they told me you got to check this one out, drop unit about a foot off the ground and yea i tried it about 8 times then almost threw it across the yard, oh well i hate being negative and love to fix whats broke but the hours spent i could be making money and just buy another, thank you
Feb 26, 2009 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
