Question about Whirlpool GR399LXHS Electric Kitchen Range
My Whirlpool Gold oven console will only respond to certain numbers. At the moment I can only use the number '4'. So I can Bake on 444 degrees! or 4 degrees which defaults to the lowest setting of 170. Is this a problem with the sensors or the computer or what? Help! I am supposed to host Christmas this year :(
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the control board. Here is the part to order.
There is also a video on that page to show you how to make the repair.
All parts come with a 365 day, any part, any reason return policy.
Posted on Oct 21, 2013
  • 1894 Answers
SOURCE: Whirlpool Gold Accubake self-cleaning gas oven door lock solenoid
i think there is some kind of shorting somewhere.
Posted on Jun 12, 2008
SOURCE: Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Posted on Apr 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Posted on Apr 20, 2009
heatman101
  • 43501 Answers
SOURCE: Doesn't get to correct temp set.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 06, 2010
marka19
  • 1430 Answers
SOURCE: Whirlpool Gold GS 445LEMS - All digital functions
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Oct 30, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Cooking controls on left side of panel seems to not be working on Whirlpool Gold wall oven
Hello Margaret! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name phone, reviewer name (Margaret Gulan) number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 20, 2017 | Whirlpool Kitchen Ranges
I have a whirlpool gold, serial # GBS277PDB11 oven. After using the self cleaning my oven doesn't heat. Is there a reset button?
Hello Margaret Gulan! We are terribly sorry to hear of your concern with your Whirlpool Oven. You may reset the Oven by disconnecting the power for a complete minute. Either by the plug or shutting off at the breaker in the home. If that does not resolve the issue then please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer id (Margaret Gulan), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 17, 2017 | Whirlpool Ovens
When I press the Bake Button it only heats to 175 degrees instead of 350. Using the temp up Button the maximum heat is 260 degrees. How do I return to the proper settings?
Hello Jim;
My name is Peter. I am a retired Sears Home Services/A&E Factory Service field service appliance technician.
The information in regards to your model number does not match any known range. The model number is on a metal plate on the face of your oven when you open the door.
There are several components that effect the control of your oven temperature.
1.) Is your oven electric or gas?
2.) If electric do you see any sparking on the heating element?
3.) Does your broiler work?
I really do not know what you have. Give me the model number or call me @ 443-306-1362 and I will try to help you.
Peter Goodwin
Glen Burnie, MD
Jan 30, 2015 | Kitchen Ranges
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
Oven is 75 degrees off temperature setting. what do I do?
Are you sure that no one has been taking the control nob off of the dial and turning it as a prank?
Feb 08, 2012 | Whirlpool Accubake RF362LXTS Electric...
I have a whirlpool gold oven that after cleaning the door was locked, after opening door would not bake. Replaced the thermostat (tod) {8300802}that was bad but now the keypad just beeps. Ok, so I replaced...
We are sorry to hear of the problem with your Whirlpool oven. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your oven.
Apr 14, 2017 | Whirlpool GW395 Gas Kitchen Range
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Oven clicks to self cleans or f3, the door locks and food burns
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
EO F2 Lock message on oven panel
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Dec 29, 2008 | Ovens
Whirlpool GR399LXHS Electric Kitchen Range Logo
49 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
