Question about Zanussi Washing Machines
I need to replace the program knob, the machine is 24 yrs bought in Holland, not the new ones of pushing the knob to start. Naomi
    Master:
  • 818 Answers
Look at your new knob-do you have a new one-old knob should pull off with a fair amount of pressure-then just push new knob on-look for a flat spot in new knob and be sure to line that up with the shaft on machine-cheers Denny
Posted on Oct 16, 2013
3 Suggested Answers
SOURCE: The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
Posted on May 04, 2009
gary1121
  • 332 Answers
SOURCE: Removing the Push-to-turn-on knob
if you pull on the knob it will come off it has a metal clip that is pretty snug on the stem but it will come off, you still have to take the cack cover plate off to get to the switch and do the actual replacement
Posted on May 29, 2009
GE Advantium microwave large round turn to set/push to set or start knob will not work when pushed. Can just the knob and a contact be replaced or do I need a whole new panel? Also, it is 12 years old
To replace parts in a twelve year old machine will probably cost almost as much as a new one ubnles you can get the parts cheap and do it yourself. I myself would not attempt to do it. We just bought a good size one for one hundred dollars and they told us that the new ones will not last as long as the old one. It was 18 years old.
Jan 13, 2015 | GE Microwave Ovens
Once dishwasher starts wash cyle, it keeps running wash cyle indefinitely. what do i need to do
Possible that the diswasher control panel is not in order and is a suspect. remove power for some to reset the board. Try with different program and if the same action continues check with the panel board before you can think of swapping to confirm the case.
Jun 28, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a jc penney serger that I bought probably 20 years ago. It has been at least 10 yrs since I have used it, and now I can't find the power cord for it, and it has lost one of the colored knob
try these sites--some of these sites you may have to email them about the parts
ebay
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 30, 2012 | Sewing Machines
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Sep 03, 2009 | Indesit W 123 Front Load Washer
FIsher Paykel DD6031, motor needs replaced, Is it worth it?
dont bother repairing the Unit the Timer is Fried, Its worth about $350.00 W/ Labour, I'd buy a new one Personally. Goto ajmadison.com they have fantastic deals.
May 14, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
May 04, 2009 | GE WDSR2080D Top Load Washer
Dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
