Question about Vestax PMC-05Pro II professional mixing controller
When was the Vestax PMC 05 Pro II released and how much was the original price brand new? how much do you think they are worth now?
3 Suggested Answers
  • 5603 Answers
SOURCE: need to change the fuse in a vestax pmc
Sorry, since the mixer is powered by a "wall wart" adapter, it is UNLIKELY there are fuses in the unit.
If it is inoperative, then check the voltage of your power adapter. If you by chance connected a wrong adapter, try the correct one. It is possible damage was done in this case that is not so easily fixed as changing a fuse. The correct adapter looks to be a type AC14 which LOOKS to be a 15 volt DC, 500 ma, with negative on the pin.
Posted on Jan 25, 2010
  • 3 Answers
SOURCE: Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Posted on Mar 22, 2010
Pmc 17 repair
VESTAX US - 2750 29th Ave. Suite 15 - Hollywood FL 33020 - 954-926-6622 Fax. 954-926-3304
If you know exactly which diode you need you could post that. Would be easier with some specifics.
Apr 11, 2014 | Music
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
Power cord get really hot.
If mixer is working properly, check the rating of the adapter versus what the unit requires. Some sites indicate this requires a 12 volt adapter rated at 1.2 amps.
Feb 08, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
I have received death note,what should i do?
Talk to a teacher you trust, Talk to your parents, phone a help line, take it to your local police.
Jul 04, 2010 | Vestax Pmc 280 DJ Mixer
Headphone channel is broken, outputs fuzzy, needs service
I'd try this company:http://www.wdgreenhill.com/ I had good service from them and I live in Canada. They are in Rochford Essex.
May 14, 2010 | Vestax Pmc 280 DJ Mixer
Feb 22, 2010 | Vestax Vci 100 Midi Controller
Power light comes on but nothing else works.
There is a possibility that your plug on the adapter is the wrong polarity. See if the polarity is marked on your mixer by the power adapter jack.
Feb 03, 2010 | Vestax Pmc 280 DJ Mixer
Need to change the fuse in a vestax pmc
Jan 25, 2010 | Vestax Pmc 280 DJ Mixer
Vestax PMC-05Pro II professional mixing controller Logo
24 people viewed this question
Top Vestax Music Experts
Michial Gueffroy
Jeff Turcotte
Jeff Turcotte
Are you a Vestax Music Expert? Answer questions, earn points and help others
