Question about Dewalt Tools & Hardware - Others
Have a d15844 dewalt nailer - it's fairly new and not used in heavy duty projects so far. It fell off a 5 ft ladder into the grass. After that it did not work. Nails fly off nailer randomly and it also makes a loud noise. I noticed a slight bent on nose spring but then it may need to be dissasembled around trigger area. Please help.
rowdy45176
  • 2176 Answers
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Posted on Feb 21, 2009
mrhappyface
  • 205 Answers
SOURCE: makita AN 901 framing nailer blows nose end apart
not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Posted on May 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: My brad nailer will not shoot any nails. When I
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Posted on Oct 16, 2009
  • 10 Answers
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
Posted on Oct 31, 2009
  • 142 Answers
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Posted on Dec 31, 2009
Well i put a seal kit in my dewalt d15844 nail gun and the air still comes out where the nail do,can anyone help me
You must have damaged the seal when you installed it, you used seal lube when replacing them correct?
Nov 02, 2016 | Dewalt Air Tools & Compressors
Dewalt framing nailer D51822 type 1
you may have to hand push the anvil back up , using too much air pressure will ever time cause this
Jun 13, 2016 | Dewalt Heavy - Duty 31° Clipped Head...
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Air compressor does not shut off at 150 psi
If its new take it back. If its used,, the pressure regulator is not working. Make sure the pop off valve is working, safety first.
Oct 10, 2013 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Inlet air preasure
Dewalt guns use between 70 and 120 psi. I use 100 psi on all framing guns when testing, however the nailer will last longer if you use lower pressure (only whats needed to drive nail into work, depending on type of wood) . When too much pressure is used, extra force is absorbed by the lower bumper and nose area of gun.
The address below is dewalt service and has all the info about your nailer. Just enter the model number and look for pdf file. Check your model number for safety recall. Good luck
www.servicenet.dewalt.com
Jun 22, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt D51850 framing nailer leaks air continuously
You could have broken internal parts but more likely you have broken or worn o-rings inside the nailer. You can go to the Dewalt service site at, http://servicenet.dewalt.com/, search for your model number and get a good breakdown of the nailer and order the parts you need to rebuild it. If you replace any o-rings, replace all of them.
May 25, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
My dewalt heavy duty coil roofing nailer seems to misfire when shooting nails. The nails it shoots they come out slow, then it misses a bunch of them. I think the plunger is stuck. How do I get this...
before tearing apart spray gun plunger and shaft with carb cleaner than spray with a spray lube like wd40 sometimes the plunger gets debris on it if still misfiring call dewalts 800 number they can advise of local repair shop and also advise if problem can be fixed by u
Jan 23, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Dewalt D51822 leaks air
its a seal leak, but if it's under warrenty, send it back
it's not worth voiding the warranty by doing it yourself
Dec 09, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt compressor not filling with air constantly running
hi your problem seems to lie with the valves in the cylinder head not sealing i suggest you obtain a new valve set and replace said items
hope this helps
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Tools & Hardware - Others Logo
37 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
