Question about Dryers
Mod.51029 light switch has no energy going to or from the switch.
    Master:
  • 452 Answers
Blown fuse?
Posted on Oct 17, 2013
Hitachi 50"comes for about 10 seconds then cuts off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 03, 2016 | Hitachi 50V500 50 in. HD-Ready LCD...
THE LIGHT DOESNOT GO OFWHEN THE DOOR CLOSE AGAIN AFTER OPENING
You should have a switch the door hits to cycle the light on and off. Open the door and press the switch with your finger. If the light stays on, your switch has failed
Aug 03, 2016 | Amana DD01E DigiSmart Collection DigiDoor...
Does the total power dissipated on the circuit increase, decrease, or temains the same when the switch is close.
In any circuit, when the switch completes the circuit power will be dissipated in the form of work or heat. Work is the energy used to perform a function, such as turning a motor. Heat is energy lost due to circuit resistance, and the power used to create it.
Think of an incandescent light bulb. When the switch is turned on, the bulb uses energy to create light by passing current through a high resistance wire, heating it up. Here some of the energy produced is lost as heat from the light bulb itself.
Mar 31, 2015 | Cars & Trucks
How do I change a light switch
Go to the link below. It is for the part and has repair videos. Door Switch 240505801
Oct 12, 2014 | Kenmore Refrigerators
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
Superswitch programmable wall light switch - when timer is in off position lights glow dim when using energy saving bulbs.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Manual say 'incandescent' light bulbs only.
What can I control with my EJ351C? The EJ351C timer is to be used with standard base incandescent light bulbs only! It should not be used to control lighting such as:
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
Oct 16, 2010 | Intermatic Programmable 24 Wall Switch...
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
One of my five EJ500C timers controls 6 outdoor landscaping lights behind my house. I installed the energy saving (coil type) bulbs and, at roughly 15 minute intervals after the lights come on at dusk, the...
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Feb 27, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
GE WASHER MOD.WPSR3100 DRIPS OIL HOW TO GET TO IT
your bearings are gone that's why you have oil you have a big job on your hands if i was you i would go down to your local second hand appliance shop they might take on the job and its not all the dear so try and ask first before wasting money doing it your self.
Dec 08, 2007 | GE Energy Star WCVH6260F Front Load Washer
Dryers Logo
44 people viewed this question
Top Dryers Experts
