Question about Charging & Starting Systems for Oldsmobile Custom Cruiser
How do I fix the problem with po183 code and po462 code if there still showing up after the problem is fixed
    Problem Solver:
  • 8 Answers
If you fixed the problem and erased the codes and they do not come back, then chances are the problem is fixed. If you fixed the problem and erased the codes and the codes came back, then there is still a problem. Shorts can be tricky. Sometimes when you replace a shorted part you find out that was not the only shorted part after you install it or that part was not shorted to begin with and there was an open in the circuit that the part you replaced was part of. You are going to have to start troubleshooting. You know what the codes are and now you know what they mean and what the possible causes are. Now you need to start testing to see if there is power going to those parts and if the resistance in the wiring leading to them has the correct resistance required to carry voltage to those parts to make them function properly. The parts that you replaced and the parts that are showing to possibly be faulty due to the codes that populated are part of a large circuit of other wiring, components and control modules. If any of those components are malfunctioning or shorted then they can cause codes to populate for parts on that circuit that are not in fact faulty at all but rely on the part of that circuit that is faulty in order to function. There is an open somewhere in that circuit. You will have to start testing each part in that circuit to find it. Start with the most obvious. I would test the sensors related to the codes and then backtrack through the wiring diagram of that circuit to find out how they relate to the part you replaced. You can also check the easy, are you getting fuel and spark? I am assuming that since it will not start and you are getting fuel system related codes that you are not getting any fuel. There is something probably causing power to stop from going to the pump. As you are troubleshooting you will start to unveil answers to these questions.
Posted on Oct 15, 2013
How do i fix my 2002 Altima that will not start?
Depends on the make but most likely i would say it is a bad connection, so i would check to see if the wires are possibly damaged. The two codes dont really relate problamatically.
If you have a volt meter you can check to see if the connections are grounded or damaged. I would start there. If you dont have a volt meter a cheap one is about 20$ and you can find on youtube how to use it.
Oct 08, 2015 | Cars & Trucks
Code p0340, p0462 on subaru outback 2001
Po340 is a cam shaft sensor and po462 is low voltage on your fuel guage. So i assume you are haveing fuel level issues. If you can turn wrenches you can do these repairs yourself. Just do a google search and you can get some youtube videos of sensor replacement and location. Have fun.
Aug 29, 2014 | 2001 Subaru Outback
Code PO462
A Generic PO462 is the Fuel Level Sensor
Was that replaced as part of the fuel pump assy?
I would google the code & your vehicle, for a solution
May be going back there to check the wiring for a
voltage drop
Apr 09, 2014 | 2007 Nissan Quest 3.5 Minivan
I removed a shorted out climate control module now my 2006 Nissan maxima will not start.2 codes are poping up po183 and po462 whats the problem please
P0183 is set when an excessively high voltage from the fuel tank temperature sensor is sent to the engine control module. Possible causes are the sensor circuit is open or shorted or the fuel tank temp sensor is malfunctioning.
P0462 is set when an excessively high voltage is sent from the fuel level sensor to the engine control module. Possible causes are the CAN communication line is open or shorted, the sensor circuit is open or shorted, or a malfunctioning fuel level sensor or unified meter and a/c amp
Oct 14, 2013 | Charging & Starting Systems for Oldsmobile...
I have the po183 code and I am not getting no fuel I don't hear the fuel pump kick on the car has been sitting for a few years
your fuel pump needs to be changed u can try and tap on the gas tank that might work but either way u have to replace it
Aug 01, 2013 | Vehicle Parts & Accessories
Po462 nissan mini van
Hi Barbara,here's a link to your code,it says to erase code and fill up with gas and see if code comes back,if it does then sensor is bad.Autozone may be able to remove code for free,they have scanners,call first.
Jul 09, 2013 | 2007 Nissan Quest 3.5 Minivan
2005 taurus po462 and b1202 codes
PO462--Fuel Level Sensor Circuit Low Input
Sep 21, 2012 | 2005 Ford Taurus
I have a nissan altima 05 3.5L engine service light just came on and my scanner read these codes P0722 and p0717 p0462 and p0500 are these things i can fix on my own?
CODE PO462 FUEL TANK LEVEL SENSOR VOLTAGE LOW. CODE PO717 TURBINE SHAFT SPEED SPEED SENSOR NO SIGNAL. CODE PO722 OUTPUT SHAFT SPEED SENSOR NO SIGNAL. CODE PO500 VECHICLE SPEED SENSOR CIRCUIT MALFUNCTION. SOUND LIKE YOU HAVE TCM ECM PROBLEMS GETTING TOO MANY CODES. COULD HAVE LOOSE GROUND WIRE TO THE TCM AND ECM.
Aug 06, 2011 | 2005 Nissan Altima
How repair replace part for code p183,p420,p430,p462
PO183--Engine Fuel Temp Sensor,Verify PID Value
PO420---Catalyst System Efficiency Below Threshold (Bank1),O2 Sensors,Coolant Temp Sensor,Misfiring,etc
PO430--- Catalyst (Bank2)
PO462---Fuel Level Sensor Circuit Low Input,pump module,etc
Well----Codes do not tell you what part to replace,Just that a possible system failure has ocurred
Unless you have a scanner,not a code reader and a trouble chart,your done.
No experience,done
I would speculate, that you only have a couple of, not too serious issues,but wouldn't guess,it doesn't work that way.
Always test,and only replace things if they fail a test.
Is the battery okey and alternator output good ?
Oct 21, 2010 | 2004 Nissan Titan
Charging & Starting Systems for Oldsmobile Custom Cruiser Logo
71 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
