Question about A.O. Smith Ao Smith Bt-80 Conservationist Commercial Tank Type Water Heater Nat
My water heater heats everything except my lower shower
    Master:
  • 381 Answers
Let's walk our way thru this one: I assume you have an upstairs shower, and a downstairs shower?-- Are you able to follow the pipes coming out of the Hot Water Heater?-- Can you trace where the pipes to the upstairs shower go?-- And what about the pipes to the lower shower? -- Do they BOTH come off the HOT water pipes coming out of the top of the HW Heater?
A big help in tracing pipes, is by having the hot water run in the Shower that is getting HOT water-- Feel the HOT! pipe?-- Now-- shut that water off, and go to the lower shower-- When it is running, can you hear water flowing out of the pipes at the top of the Hot Water Tanks?-- or do you feel Cold water moving-- Can you travels where it is flowing from? Get back with me, and tell me what you are feeling, and hearing-- Mack B
Posted on Oct 16, 2013
I have model AH21 Tankless Water Heater and it is not heating the water
try these steps - hope it helps
  • Selected temperature on your tankless water heater is too high. Select the lower temperature.
  • Inlet filter is dirty... clean it.
  • Make sure that there are no water path obstructions, including faucet aerators, shower heads...
  • Is the heater using the specified gas type?
  • Temperature sensors are loose... ensure that sensors are firmly mounted and are making contacts.
Jun 02, 2012 | RTO American Heat Tankless Electric Water...
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
My rinnai heater keeps my water running hot and cold, hot and cold and I can't have a decent shower! How do I stop it from doing that?
if it has been constant from instalation it might be that ur shower head is rated too low to get enogh gpm ( gallons per minute) it will tell u most of the time around the shower head where it threads onto the spot of the wall what the gpm is. alot of the energy saver heads are restricting tehgpm to 1.5 or .5 gpms to conserve water well the water heater will only operate correctally around .5 gpm depending on model so if u are not pulling enough water u will not turn the water heater on to get ur hot water all the time so go to lowes ( or locally trusted hardware) and get a new shower head make shure u look for the gpm on teh head and check in ur owners manual to see what gpm ur water heater kicks on
P.S. if ur shower head is rated at higher gpm say 1.5 and it is corroded or pluged up say with lime it is going to restrict it causing a lower gpm
Jan 13, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Water heats, then turns cold
These units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 29, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
A.O. Smith Ao Smith Bt-80 Conservationist Commercial Tank Type Water Heater Nat Logo
91 people viewed this question
Top A.O. Smith Water Heaters Experts
bobalix
rdjagger
Mack Baxter
Are you an A.O. Smith Water Heater Expert? Answer questions, earn points and help others
