Question about Whirlpool WTW4800XQ Top Load Washer Washing Machine
Whirlpool WTW4800 Washer won't complete calibration mode cycle. Drain pump actuates, then the agitator actuates a few times while drain pump continues on for minutes. No spin of basket. Concerned it going to burn out the drain pump so I cancel calibration mode. Automatic Test Mode completes just fine.
Coldcut
  • 1554 Answers
SOURCE: My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Posted on Oct 31, 2008
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Tub won't drain
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.7bce33c.jpg025e16d.gif
More here
bypass it here for testing purposes. How it works: direct drive washer
Posted on Jul 12, 2010
caroldon
  • 17130 Answers
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Posted on Oct 30, 2011
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
My whirlpool washer agitates but will not pump out the water. I thought the timer switch assembly was bad so I replaced it. Still no water pump. I can not find the Model Number tag on the washer...
Drain Pump Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Aug 03, 2017 | Whirlpool LSQ9520L Top Load Washer
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool WTW4800XQ Top Load Washer Washing Machine Logo
675 people viewed this question
Dan Webster
Dan Webster
Sal De
