Question about Zoom Q3hd Camcorder
I have a 16gb scandisk memory card. When I insert it into the camcorder I get a "format error" sign and my memory card doesn't work.
Camera says that 16GB scandisk card is full when I try to take picture
Try formating the SD card before you start taking photos. Go to the camera's Menu and scroll through the settings to Format memory card.
Jun 17, 2012 | Cameras
Scandisk memory card keeps saying error
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Apr 27, 2010 | SanDisk 4GB microSDHC Memory Card
Memory card error replaced card but still get error message?
Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
Feb 25, 2010 | JVC GZ-MC500 Memory Card Camcorder
When i turn my camera on it says memory card error
You probably need to format the card in the camera. This will erase all the pictures so download them first.
Sep 18, 2009 | Cameras
How to format a SD memory card for samsung
Hi Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sep 09, 2009 | Samsung SC-X210L Mini DV Digital Camcorder
    SD card - memeory card parameter error
    Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
    Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
    Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
    Hi ,Welcome
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Cant format 16gb sd memory card in canon mv830 camcorder
    Hello There
  • Apr 12, 2009 | Canon MV830 Mini DV Digital Camcorder
    Beeping
    Hi
    call your camcorder manufacturer and inquire for a firmware that supports the memory stick. chances are its not compatible with the camcorder since this handles large memory.\
    Hope this help
    Jan 11, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    Zoom Q3hd Camcorder Logo
    24 people viewed this question
    Top Zoom Video Cameras Experts
    matt
    matt
    Are you a Zoom Video Camera Expert? Answer questions, earn points and help others
