Question about Whirlpool LHW0050PQ Front Load Washer
LHW0050PQ will not transition from wash to rinse - instead END light flashes. Must turn to STOP, wait 2 minutes, turnoff machine, turn back on and then restart on a rinse cycle. Otherwise everything seems to work OK including drain pump. What could be preventing this transition (pressure switch, door switch, or ???)?
    Master:
  • 492 Answers
Usually it's the timer that goes bad. I replaced mine for $30.
Posted on Oct 15, 2013
Testimonial: "NO timer - only electronic board and all functions work fine during service manual test sequences."
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: The machine gets stuck mid cycle
If the inlet valve and the pump work correctly then it must be a problem with the timer control.
Here you find a replacement for the timer control assembly, just enter the model number.
Same here, free diagrams, and you can buy parts, enter the model number.
Here instead you find repairing tips : What is wrong with your Washing Machine?.
Regards
Posted on Oct 11, 2008
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Why won't my washing machine stop cycling?
    Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
    Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
    Novotronic washer w1918 jumps violently when transitioning from main wash to rinse 1-2 with 21 minutes to go to end of wash cycle
    If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
    May 19, 2014 | Miele Novotronic W1918A Front Load Washer
    I have s tecnik washing machine that shows flashing lights on start button along with flashing lights on 800 rinse speed and rinse and wash, I have cleaned out the filter which was blocked but can not get...
    plug machine in
    turn timer knob to 6 o'clock position
    press and hold spin speed button
    turn timer knob 1 click clockwise
    release spin speed button
    now turn programmer knob to off wait 5 secs and turn on
    I had the exact same issueI
    hopefully it will work but you may have to repeat a few times and some engineers say it only works with motor unplugged but I have not found that.
    Apr 07, 2014 | Tecnik Washing Machines
    Model Gw709AU
    When you start your machine is the water just go stop go stop,
    Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
    It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
    Your error code will determine this.
    Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
    To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
    j8paojvh5jrgaaaaabjru5erkjggg==
    Feb 20, 2013 | Fisher and Paykel Washing Machines
    Whirlpool front load washer Model# LHW0050PQ3 Which board do I need?
    Sounds like possibly a bad control board.
    Try to unplug your washer for 5 minutes then plug it in and run a load and see if it still does it.If not, you will need to replace the main control board.
    May 11, 2012 | Whirlpool LHW0050PQ Front Load Washer
    I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
    My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
    Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
    Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
    Step 1: put the plug back in and turn the power back on.
    Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
    Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
    Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
    Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
    Hopefully the cycle will run without a problem.
    Mar 26, 2011 | Electrolux Washing Machines
    Door to washer won't open
    You just have to wait a few minutes after the spin cycle is over and the "done" light is on. At least that always works for me.
    Jun 16, 2009 | Whirlpool LHW0050PQ Front Load Washer
    Whirlpool LHW0050PQ Front Load Washer Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
