Question about Garden
Replaced battery (old anyway) on john deere lx288. battery light still on. possible sources of problem?
  • 2,113 Answers
Follow the gauge wires to where it is grounded, dismantle and clean the ground. Also clean the battery posts. Check that the battery is charging when the motor is running... if not then replace or repair the magneto or alternator where applicable.
Posted on Oct 15, 2013
Testimonial: "thanks, will try later this week. also have a broken pipe flooding the house to fix. good week i have going!"
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
  • 10 Answers
SOURCE: John Deere X324 drains the battery
might have a short in your seloniod switch if you unhook pos from it and there is spark hooking up its probably the short
Posted on Sep 08, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
Does a John Deere model LX279 only have one belt
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX255 LX266 LX277 LX277AWS LX279 LX288 LAWN GARDEN TRACTOR...
Apr 27, 2017 | John Deere Garden
Snow blower attachment M02462X052302 will it fit a GT262 tractor? Attachment and tractor are John Deere.
I see snow blowers as an option but 262 is not included in the list.
It says it fits 212,F510,F525,GT275, Lx172,LX173,LX176, LX178,LX186,LX188,LX255, LX266,LX277,LX277 AWS,LX279,LX280,LX288, LX289,STX30,STX38,STX46
Not to say you can't make it fit but it will take some work.
Best,
Joe
Sep 30, 2016 | Garden
Bought new battery for john deer lawn mower, it keeps going dead. yellow light on all the the time, what is the yellow light for?
Possible the charging unit on the tractor is shorting causing a drain on the battery when it's not running. I had to replace one on my old machine. The yellow light I think is telling you there is power on some place Check you have to find out where the power is going to a meter might help test different areas. Could be different things. even the starter or a bad switch.Make sure the lights are not on.
Jul 27, 2014 | John Deere Garden
Flat idle pully keeps popping off
Is it the flat pulley on transaxle? Its missing a small e-clip.
Apr 22, 2014 | John Deere Garden
Do you have a wiring diagram for the starter on a John Deere 285 garden tractor? The old starter was removed and no wires were labeled.
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Jul 30, 2011 | John Deere Tractor Starter 285 345 2243...
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
