Question about Scotsman Kitchen Appliances - Others
I have a scottman that is putting out brown ice for awhile then stops then does it again. Any thoughts?
  • 2,113 Answers
That would happen if you have old fashioned galvanized pipes in your house... or even just one fitting that is galvanized.
Posted on Oct 15, 2013
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
Dec 31, 2015 | Heating & Cooling
Ice maker stop making ice put in new filter
probably filter backwards? or wrong filter?
why did u put new filter in? cuz it stopped already, and thought new filter should fix problem? u guys kill me
Jan 01, 2015 | LG LFX25960ST Stainless Steel French Door...
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
Scottman cu3030 max harvest-retrying, flashing code #2
The machine will try to harvest 3 times before it shuts the machine down. Is the ice thick enough to open the curtain door? if the curtain dose not open the magnet switch then the machine dose not know it has harvested the ice and will keep trying to harvest. Is the ice coming off the evaporator plate during harvest or is it hung on the plate? if hanging on the plate then system needs to be cleaned. is the harvest assist plunger working?
Oct 30, 2013 | Scotsman Refrigerators
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
My galaxy ice maker stopped working. At first i thought it was just jammed. We cleared it of ice. We thought maybe the drawer wasn't put back in correctly, took it out and put it back. Worked for a little...
ck the temt of freezer . it must be 15 deg or lower . sounds like it 20 deg and is having a hard time. set freezer to lower tempt and clean the coils undr neath and make sure the fans both top and bottom are going . as no air flow no ice. or poor cooling .. **** hope this helps / feed back pls .
Dec 23, 2009 | GALAXY Microsystems 25.4 cu. ft....
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Anti-lock light comes on.
I had the same problem on my 2000 Blazer usually when I made a slow turn. I had the ABS system disconnected, you don't need it here in NY, problem solved. You won't notice any braking change except on snow and ice you'll get normal braking not the ABS back and forth. It took just a few minutes and the mechanic didn't charge me. The light will stay on but it still passes inspection. Hope this helps.
Mar 26, 2009 | 1993 Oldsmobile Cutlass Supreme
Ice makr stop working....
Most likely you have a bad water valve. It is a duel coil valve. one side is for the ice maker and the other side for the water dispenser. If the dispenser is working then the IM side of valve could be bad. the unit comes as a complete package. Also you need to check where the water enters the freezzer to fill the ice maker as that may have frozen up. To check the ice maker, if it is a modular style, remove the front cover. Does it have a brown body with a white drive gear? Then you can jump the holes that have "T" and "H" and see if the unit cycles. You can jump H to V ans see if you have water. No water with H-V then valve could be bad
Aug 31, 2008 | Whirlpool Refrigerators
Kitchen Appliances - Others Logo
76 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
