Question about Sharp 32F-830 32" TV
28jw73h this tv takes a long time to come on when first switched on. i used to be a tv engineer along time ago but left the trade so will be able to change faulty components. i wonder if this might be a common fault,please advise thanks
    Genius:
  • 1,694 Answers
Practice visual acuity technique! Solder any/all bad connects,look for over-heated area, check caps in power supply,horiz.and vertical circuitry.Possible slow charging cap.
Posted on Sep 26, 2007
SOURCE:
Television is showing 'out of range' and nothing is happening
I can think of a couple of potential issues that might be creating this problem:
1. You have a playing card and no matter how long you look at it, the image will not change.
2. If you are using this trading-card TV in your car, it is probably not a mobile trading-card television, thus the 'out of range' message.
3. As a trading-card, it is not electric, so whatever you are doing to switch it off isn't having the desired effect because as a trading card there will be nothing different when you 'switch everything off.
I recommend you think differently about your trading card in order to fix this problem. It is a card, not a TV. If this fails, you can buy a new one on ebay for under $2.50, but I don't think it will work any better.
Dec 30, 2013 | Shawn kemp skybox 1995 hoops power
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
My check engine lt went on this morning and will not go off. any ideas? No other issues. Had the head gasket changed several mths ago along w/timing belt and water pump. Also alternator went about 2...
Take it to autozone or advance auto they will tell you what the code is for free but more than likely it's an oxygen sensor that needs replaced 9 outta 10 times that's what a check engine light is on for
Sep 15, 2011 | 2003 Subaru Baja
My grand wega 42" rear
call sony. they have been offering new tvs at a discounted price for that problem. whatever they offer take asap. yes its a throwaway tv. sony the only company that is helping customers with that problem, other manufacturers say tuff. 18002822848.
Mar 22, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
About a year ago I ran my front left tire into a curb whil it was fully cranked to the left. I got my alignment done thinking that was the problem, but everytime i turned right while driving more than idk...
The frame is unitized to the body so I would replace the car since its 5 years old. Your talking big bucks to have this repaired. A Cheif EZ Liner is a frame machine that can be used a qualified tech making $75 an hour. Your car wouild be in the shop for more than 40 hours to repair. If the whole bottom frame diamensions is tweek very bad it can take more time than a week. Trade it in
Jan 14, 2010 | 2005 Pontiac Sunfire
When I press record the light comes on and appears to be working, when I stop and rewind to re-play to make sure it is recording there is no picture or sound
it sounds as if you need the video and sound heads along with the tape travel path cleaning properly ie:remove the top cover and clean manualy PS:this should only be done if you have experiance as proper lint free clothes and cleaning fluid has to be used or you completely ruin the heads and these are expensive.
but you can buy a head cleaning tape and there are two types wet or dry i suggest through being in the trade for over 50yrs that yow use the wet one follow the insttructions on th box.you may have to do it 2 or 3 times if ithaevey soiled PS the heads get soilddue to particles of tape being left each time you use the machine. hope this helps .tv ****
Jun 12, 2009 | Samsung SRV1280 Time Lapse Vcr
Sharp 28JW73H Green tint with lines across screen
Note: unmatched Make / model info........please clarify...T.
Nov 16, 2007 | Panasonic PT-52LCX66 Projection Television
Samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Oct 16, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sharp 28JW73H
Lynda, could be why someone was selling it? It could have a bad connection inside the set somewhere that needs to be addressed asap as it will get worse, or a power regulator is bad. This will oneday make the set not turn on anymore without a repair job. Also make sure the outlet your pluging it into isent loose. Sorry i couldnt assist you more with this. Good Luck
Jul 23, 2006 | Sharp 32F-830 32" TV
Sharp 32F-830 32" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
