Question about 1988 Mercedes Benz 260E Window Regulator , 88
Window will not roll up
Windows quit working not fuse not relay not motors
    Master:
  • 444 Answers
Only item left in that circuit is the switch itself or a bad connection in between. be sure to check switch at drive door master control as well.
Posted on Oct 15, 2013
I got a 2000 Pontiac trans am and every time I turn the car on the driver side window will roll down and it won't roll back up. But the passenger side window works fine. And when the stereo works the...
How about when the radio is on & the key is off or
in your hand,if you open either front door does the radio go off
& do you lose the delayed window feature assuming you have that
If so you problem is a delayed accy relay
Next would be the front door switches
I will give you credit for what you tried
but fail to see why you would switch motor
from door to door,they work powered directly or they don't
I would think your battery would have gone dead by now
if the relay failed to time out or go to sleep
Jul 27, 2013 | Cars & Trucks
Power windows inop in 2002 monte carlo
http://mymonte.com/tech/manuals/2002montecarlo.pdf
page 6-63 to 6-69
Jan 30, 2013 | Chevrolet Cars & Trucks
My driver side window wont roll up
First check the fuses for both electric windows if they are good.The fuse box one is on the engine compartment driver side look for long retangular black box and open the fuse cover the cover should designate what the fuses and relay is for the other is on the driver side under the dashboard just above your left foot look under you should see another fuse box.If both fuses are good,then your going to have to check the window regulator which is inside each door.Open the door panel and check window regulator morethan likely the regulator assembly need to be change.You might just need the motor.The whole assembly is quite expensive.
Nov 06, 2012 | 1996 Lexus ES 300
My windows wont roll down
PROBABLY A WINDOW LIFT MOTOR, FUSE, OR RELAY. YOU CAN CHECK BY MAKING SURE THAT THE FUSES UNDER HOOD FOR WINDOW MOTOR ARE OK. IF THEY ARENT, REPLACE RELAY. IF NEITHER OF THOSE, REPLACE LIFT MOTORS.
Jul 09, 2011 | 1998 Ford Expedition
On a 2002 mercury sable the drivesrs rear window
check fuse and relay.if all is good .either switch bad or window electric motor is bad.
May 17, 2009 | 2002 Mercury Sable
Window no go
Does the power window motor run when you go to close the window, but fails to raise the glass? If this is the case, there are bushings (plastic) in the motor that wear out, and the window won't close. I found the bushings on ebay, I've heard they are also available at parts stores in 'HELP' packaging, either way it's only a few $ for them, much cheaper than replacing the motor. If the motor quits, it's probably time to change it, as long as it didn't quit from a fuse blowing, but the bushings worked for me.
Apr 12, 2009 | 1991 Ford F150
Windows wont go down or up
Check the switches for a clicking sound if you hear a clicking sound then the switches are fine. Does the driver side switch work for the windows? Check it for the click sound. Make sure it isnt a blown fuse. If you have replaced the fuse and you dont hear clicking sound it might be the switches and you can find them at a junk yard. If you have tried all these things and it still doesnt work you might need new window regulators and/or window motors or it might be a wiring problem.
Mar 08, 2009 | 1995 Pontiac Bonneville
2002 Nissan Xterra drivers power window wont roll down
Quite possibly yes...I would first check any relays and/or fuses just in case.  A few dollars for a fuse or relay is much cheeper than say $100.00 and a few hours of labor.
You can purchase just the window motors from any major auto parts stores.  You can also purchase the window motor with the regulator.  The regulator is kind of like a rope and pulley system to lift the window up and down and the motor is attached to this assembly.  It is a little more expensive but I would change both.  I always change both just in case the regulator is bad and it isn't the motor.  You will have to remove the plastic interior of the door in order to change either the motor or the motor/regulator assembly.
Any questions, feel free to ask!
Feb 04, 2009 | 2002 Nissan Xterra
1988 Mercedes Benz 260E Window Regulator , 88 Logo
71 people viewed this question
Top APA/URO Parts Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an APA/URO Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
