Question about Video Game Consoles & Games
Xbox 360.my xbox ac adapter light is orange.when i connect it to the console it will not turn on.what do i do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Its a bad power supply get a new one or it could also be telling that ur console has a malfunction
Posted on Oct 23, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: XBOX 360 power brick flashing orange and green
according to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
  • Make sure that all ventilation openings in the power supply are free to ventilate.
  • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Plug the power supply directly into a wall outlet. In other words, do not use extension cords or power strips.
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
Posted on Jun 15, 2009
SOURCE: my xbox 360 won't turn on
I know what to do.... it happened to me, but I fixed it. Ok you will need a peperclip for this to work. Take off the faceplate of the 360. And then what should have been the powerbutton, use the paperclip to hit it. It should turn on, then you can put the faceplate back on.
Posted on Jun 28, 2008
SOURCE: AC power adapter light is red what to do?
the power supply is already busted
you need to call xbox 18004699269
if you purchased the xbox within 90 days, then they can have your power supply replaced
if not you need to buy a new one
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: power cable light is orange and xbox 360 wont turn on
try checking the usb is it damaged? the pins in the usb may be shorted to ground..pry any pins up and the system will work..this happened to me.
Posted on Mar 02, 2009
My xbox ac adapter keeps indicating an orange light when it is switched on without connecting it to the console. When I plug it into the console and then switch the xbox 360 console on, the console gives...
Disconnect everything and reconnect it,if that doesn't work, try to hook it up in a different room. If you are still having problems, you need to contact customer support and may have to order a new power supply cord.
Sep 17, 2011 | Microsoft Xbox 360 Console
I played like 30 min then i went out and when i came back home at the night i couldnt turn my xbox360 ellite on and the ac adapter was blinking orange!
It sounds like your power brink may have over heated or faulted. Please see this page for information.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Aug 18, 2011 | Microsoft Xbox 360 Console
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
All of sudden the xbox wont turn on, never had problems before
well if you press the power button and light isnt on check plug connection going into console and then from console it goes back into the ac adapter. make sure its plugged in tight. To make sure ac adapter is working fine there is a small light on the side if it is green it is working fine if it is either orange or red you have a problem and may need a new adapter. If so you can get a new/used one from your local game store. hope this helps and good luck
Jan 07, 2011 | Microsoft Xbox 360 Console
I just bought a Belkin wireless router for my internet to connect with my microsoft xbox 360 wireless adapter. the light turns on the adapter but it is a amber color and not red or green like always...
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
Dec 31, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont turn on no red lights nothing happens, wat do i do?
read up on http://www.mygames-zone.com
and you will find a solution to your specific problem
My
Apr 20, 2010 | Microsoft Xbox 360 Console
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont turn on at all!
Check wires and the color of the light on the ac adapter. IF the color is orange-turned off green- on any other color- problem. Do you play alote?
Jun 23, 2009 | Microsoft Xbox 360 Console
X-box 360 has blinking orange light on ac adapter and will not turn on.
well then if the orange light does not turn on then you have not connected something the right way or thers something not plug in the right way ok
Nov 01, 2008 | Microsoft Xbox 360 Console
AC Adapter has a blinking orange light...
Try moving everything to a different room on a different electrical circuit (as in electric panel outside your house). You might have too much load on that circuit for the plugs in that room. You could try unplugging everything except tv and xbox too.
Oct 29, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
