While formatting my windows 7 i continiously press f12 or f10 for booting into the cd but after a minute it says media test failure and restarts the pc
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
When you say formatting my windows 7, are you trying to reinstall windows 7?
media test failure 99.999% usually means that the HD is unavailable. Re-seat the hard drive and see if that helps. If it doesn't try to slave the hard drive somewhere else and see if you can read it. If these don't work then your hard drive is a paper weight.
Posted on Oct 15, 2013
  • 12 Answers
SOURCE: my pc crashed and on restart it asks for me to reboot and select proper boot device OR insert boot media in selected boot device and press a key- I don't have the boot media c d and can no longer get
Listed below is link to HP drivers page for M270. The recovery Windows Media Center CD is no longer availabe for purchase. If you have a license copy of Windows XP you can install then download remaing drivers from link listed below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=339679
Posted on Apr 29, 2009
  • 7993 Answers
SOURCE: Dell GX260 wont boot a Linux Live Cd
Could the boot record on the CD be damaged? Try it on another computer to find out. As the live CD loads the program in RAM, you need to see if your system has enough RAM (It depends on the minimum amount of RAM required to run the particular Linux Distribution)
By the way if you are interested in installing Linux inside Windows XP without creating a separate partition, Ubuntu offers this.
Hope it helps.
Posted on Aug 30, 2009
  • 2666 Answers
SOURCE: PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Posted on Sep 18, 2009
bob_computer
  • 3153 Answers
SOURCE: compaq presario 5000 desktop won't boot!
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 24, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Dell Dimension 4600. I need to re-install
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Posted on Oct 29, 2009
Diskette 0 seek startup failure
restart your system and press delete to enter the bios mode and change the boot options set 1st boot device as cd/DVD rom and 2nd boot device as HDD if you are not using floppy drive just disable it. After finishing the changes press f10 to save the changes and exit
Feb 24, 2012 | Microsoft Windows Vista Home Premium with...
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
How to reboot a XP4 computer
1 first insert the windows cd in cd/dvd rom 2 chek in the bios if the first boot device is the cd/dvd rom 3 vhen it boots it will say press any key to boot from cd 4 after loading all the data you must format drive C 5 after formating it will restart instaling windows you must insert the windows cd key thats all
May 16, 2011 | Microsoft Windows XP Professional
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
Installing seven
install windows 7 ok i like to change boot formate f12 when asked in begining push f2 then change boot format to f12 then f10 exsept then restart computer put windows push f12 run windows under d: drive.
Feb 14, 2011 | IBM x3400 Server
How can i install xp or window7 on my compaq presario cq40-601tu
For installing any operating system xp or windows 7,you need cd of windows xp or 7
First go to bios by restarting your computer and press F12 and then under advanced boot priority change the first boot option to cd
and then press F10 to save changes and restart
It will ask you to boot from cd,press enter and installation will start
Aug 06, 2010 | Computers & Internet
Acer aspire 5610 new hard drive need to load xp operating software help!
hey... to install XP to the hard drive, u need to restart the PC with XP CD in the Drive... When the computer starts up you'll need to press F10 or F12 to bring up the boot menu (it depends upon ur motherboard type).. select boot from CD n follow the instructions....
Apr 02, 2010 | Microsoft Windows XP Media Center Edition...
Windows will not start
Ok ...that message about the PXE is showing up because the computer cant find an operating system on the hard drive for some reason.
Try booting from your Vista DVD ,let setup start then running Start Up repair ....
3. If prompted, press any key to start Windows from the installation disc.
NoteIf your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computers BIOS boot order
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Jan 02, 2009 | Microsoft Windows XP Professional
I have a PX-230A CD-R and a PX-740A DVD Player/Burner. Recently my computer stopped recognizing the two drives. I got the following message when reviewing the device manager: Windows cannot load the...
sir insert the operating system cd inthe cd rom drive .and restart the system press del booten goto bios goto boot dives change frist boot devise to cdrom drive and press f10 tosave thesettings
ofter the proses disply shoes press any key to continy plese press any key in key board
ofter copying the system files one message press enter to contenu . press R for REPAIR .PRESS F3 plesr prese the R bouten to repail the os........ ofter 10 minutes your system will be restart anther 25 minutes complet your system repairing ok na
Nov 20, 2008 | Computers & Internet
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
