Question about Broan-NuTone RangeMaster RMDD3604 Kitchen Hood
Blower fan is not turning - Broan-NuTone RangeMaster RMDD3604 Kitchen Hood
    Problem Solver:
  • 5 Answers
Check to make certain that there are no obstructions or objects stopping the fan. Power off the unit, check the fan. Does it spin freely, if not check to make certain that it is not stuck or otherwise stopped. The fan can easily be replaced, but usually needs a service call to do this, be sure to get a quote as the cost may exceed the $$$ to replace the entire device.
Posted on Oct 15, 2013
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
Fan blower not working
I would say its the blower switch inside the control module.
I doubt turning the switch on and off would affect the blower motor but you could check the motor with a meter to find out.
Feb 09, 2013 | 2005 Buick Rainier
When main switch to heater is turned on, only the flame comes on - no heat or blower. Have tried numerous times to reset by turning main switch off for five minutes, but still does not work. Any...
Does the fan come on when you turn the Fan to ON at the thermostate? If it does then it could be the blower board not turning the low speed blower tap on. Or the Fan & Limit switch not working. If the fan doesn't come on in the on position then the blower motor could be out or the run capacitor.
If the blower comes on it the ON position then you can run the heat with the fan in the ON position till you can get the heat relay looked at.
Dec 21, 2010 | Heating & Cooling
Just bought a 05 SLE Bonneville...and on the way home the push button on/off fan button would not turn the fans on. The fans worked fine when the car was driven up from North Carolina. In Minnesota, we...
After talking to a local mechanic, he suggested tapping on the blower motor. I tried that, and the blower motor did work. At first he thought it was the blower control module. I had the blower motor replaced, and all is fine now.
Jan 23, 2010 | 2005 Pontiac Bonneville
No air coming out of vents when air is turned on. the fuses are all ok
2 things come to mind: can you hear the fan turning?
if not check for power at fan location. If there is power and the fan isnt spinning replace the fan. If there is no power
there is a problem with the fan circuit which includes wiring fuse (you stated were ok) and Fan speed switch (might be a module)
Or there is a blockage it is possible for your heater core and evaporator to plug up with dust .
Oct 27, 2009 | 2006 Chrysler Town & Country
Blower will not turn on when a/c compressor comes on - tstat ok fuses ok
You should have a fan relay on your furnace that would control your fan in air conditioning and that sounds like you are needing
May 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Broan-NuTone RangeMaster RMDD3604 Kitchen Hood Logo
137 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
