Question about Canon MP560 All-In-One InkJet Printer
My printer is not printing black ink, although both black cartridge ink levels are are 3/4 full. I have reset to factory settings and cleaned the print heads.
    Problem Solver:
  • 5 Answers
Leave the print head ( not the whole cartridge!) soaking overnight in a little puddle of solvent e.g. print head cleaner or alcohol. This is much more effective than the printer clean program or a quick rub with a cotton bud.
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
  • 1606 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
My pro905 stopped printing in black although cartridge is showing 50% full. what could be the problem?
Make sure you are using genuine Lexmark cartridges. It could be that your black cartridge needs cleaning. Try to do the Deep Clean Printhead function on the printer. Press Ink Levels -> press More Options -> select Deep Clean Printhead. The printer will then print a clean cartridge nozzles page. If black ink is not printed on the page, you may need to update your printer's firmware. The update corrects print quality issues on your printer. You can easily download and install the update using this link Lexmark Platinum Pro905 Firmware Update. Download and install the Pro905 update. Thanks.
Jan 04, 2011 | Lexmark Platinum Pro905 multifunction...
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon mx300 not printing
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon MX300 Office All-In-One Printer
Hp officejet 5510 remove and check black cartridge message and i replaced the black to new one.
Hi Shaharz !
As per the information you have provided, I understand that you are receiving an error "Remove and check black ink cartridge" on the All-In-One display screen. If yes, perform the below steps.
Let me provide you the cause of the issue. The most cause of the issue is that if you are using refilled, re manufacture ink cartridges, cartridge is not fitting properly, wrong cartridge no. However, perform the below steps to resolve the issue.
1. Remove the print cartridges from the printer.
2. Clean the print cartridges using the lint free cloth both the cartridges heads as well as inside the printer.
3.Follow the steps below to power cycle your all-in-one:
a. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
b. Wait 30 seconds.
c. Plug in the power cable to All-in-One and also to wall outlet.
4. Insert only the black ink cartridge first and check the message on the printer.
If the issue is with the black ink cartridge then the same message will be appears on the printer. If not it will prompt you to insert the color ink cartridge.
Do the same procedure with the color ink cartridge.
If the issue persist, then it shows that the issue is with the black ink cartridge. check the expiry date of the print cartridges and try to replace it.
I believe the issue is with the printer itself. However, the printer using the HP 56 and 57 ink cartridges.
As you have mentioned that you have already replaced the black ink cartridge. Then it confirms that the issue is with the printer. However, you can try resetting of the printer to its default settings and check for the issue.
To reset the printer, perform the below steps.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
The printer might be turned off after performing the above steps, so no need to worry about that.
Then turn on the printer and check for the result.
Hope this will helps you a lot!!!
With Regards
Mike.
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset the ink memory level after replacing cartridge
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Apr 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X2550 ink cartridge refill
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Hp 6110 printer
The issue that you are experiencing might be due to various reasons.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
Please check the same and try the below given instructions to get the issue resolved.
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings :
Note:
This should resolve the issue.
Wish you good luck!
Regards,
Lawrence
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon MP560 All-In-One InkJet Printer Logo
49 people viewed this question
old marine
old marine
