Question about Microwave Ovens
Doesn't heat Microwave stopped heating, fan stopped running, but light comes on and timer runs.
  • Benelatus May 11, 2010
    First Question,
    How old is the microwave?
    Second Question,
    How skilled are you technically.
    If the answer to the second question is "not very" then, junk the microwave. Why? there's a possibility that there's a problem with the magnetron and/or its power supply. To find this out needs some dismantling and you should know that there are 5,000 [five thousand] volts waiting inside to trap [or kill] the unwary. Not only the 5 Kv. but the power supply has sufficient power behind it to kill.
  • 3,037 Answers
Sounds like the magnetron has failed possibly. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
Will not heat up but it turns on and runs
the light won't come on how can i get the light bulb out?
Jun 24, 2010 | Magic Chef CMV1000B Microwave Oven
The microwave timer runs but turnable plate doesn,t rotate and the heating elements doesn't comes on
you need a new microwave. There are no heating elements in mocrowaves just micro-waces. It only heats moisture it does not heat objects. It is to dangerous to replace the actual device that heats liquids.
Jan 24, 2010 | Emerson Microwave Ovens
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Apr 26, 2007 | Sharp R-1492 Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
