Question about Sansui Televison & Video
Volume up the voice is disappear
Hi I have problem in my LCD TV Sansui model 4207 DS when volume gos up the voice is disappear Thanks in advance for your help doron.
    Problem Solver:
  • 8 Answers
Return the tv setting to default and if it continue let a technician repair it
Posted on Oct 15, 2013
JMuskovitz
  • 135 Answers
SOURCE: Humming noice
I have seen similar problems (features?) with Syntax LCD TVs. One thing to try is to make sure that the backlight brightness is set to its highest setting. On my Syntax, when this is set to a darker setting, it produces annoying hum through the speakers. Mine also is smart about turning *off* the audio amplifier when set to zero (or mute), which sounds like the behavior you are describing.
Posted on Apr 17, 2007
  • 15 Answers
SOURCE: PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Posted on Feb 23, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
skotkolr
  • 558 Answers
SOURCE: significant volume decrease when using Comcast cable box
you might have to talk to comcast about that most signals are low for reasons of conservation of bandwidth, they may also be sending 5.1 which tends to be lower volume and adds surround in.
mono is always loud, and that is what you get with 75 ohm coaxial cable (single screw in ).
hope this helps.
Posted on Apr 06, 2009
VINsanity
SOURCE: Devant LCD tv, volume wont stay up. I increase the
CALL 3400606 OR VISIT WWW.EMPIRE1ELECTRONICS.WEEBLY.COM,THEY CAN HELP YOU.
Posted on Oct 18, 2011
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
Buzzing sound from hdlcd185w series A
Return tv to store for exchange or call Sansui customer service. They will arrange to exchange tv.
Jan 27, 2012 | Sansui HDLCD-1900 19 in. LCD Television
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
"TV Volume is fixed" shows up on Sony model #
Go to Audio Menu and turn On tv speakers option. "TV Volume is fixed" message will disappear.
Click Sony Support link to download user manual copy of this tv and check page-63 fro more details.
Thanks.
Dec 29, 2010 | Sony Televison & Video
Sansui 21in LCD VOLUME is lowering
If you are using a set-top box for Digital reception....check the output volume setting by going to the menu then audio set up section. On standard TV transmisssions the sound is often fine but on Digital....the box sets the feeder audio signal level.
Jun 29, 2009 | Sansui HDLCD3210 32 in. LCD TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Sansui tv less than 1 yr old
first thing is sound as welas vidio both are distreb are only sound? make once auto tune are chick your sond system was right ex; bg -dk -i
May 26, 2008 | Tvone LM-1501R 15" Flat Panel LCD Monitor
Sansui tv/vcr combo is stuck on highest volume.
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
Feb 08, 2008 | Sansui COM312AD 13" TV/VCR Combo
Televison & Video Logo
43 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
