Question about Singer Sewing Machines
Singer 2210/replaced gear/now needle bobbing cam out of sync
I had to replace a busted gear on my wife's sewing machine. now the needle/bobbing is not in sync. how do i adjust the timing of the neecdle/cam
  • Anonymous Mar 22, 2014
    singer sewing maching
  • 18 Answers
Look here:
http://www.vacsew.com/repair/singer-600-timing.html
Posted on Oct 06, 2009
New home sewing machine is not picking the bobbing thread SL2022.did the adjustment,cleaned up,oil too,still skips when I sewing ,but now is not sewing at all
Install a different brand new needle.
If that doesn't work, the timing is probably off. Search for sewing machine timing or take it for service.
Feb 09, 2017 | New Home Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
I have a brother SE-400 the metal ring that catches the top thread under the bobbing case (the bobbin housing?) hits my needle with every stitch, bending and breaking needles. The timing has been...
The metal ring sounds like the hook you are talking about.
Timing is only one of the issues you must also adjust the needle to hook clearance and needle bar height. The tip of the hook must pass above the eye of the needle in the scarf on the back of the needle without touching the needle. Who adjusted the timing and what did they do?
Oct 13, 2013 | Brother SE400 Computerized Sewing Machine
Have needle heating the house of the bobbin case on pfaff 1222e
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Nov 29, 2012 | Sewing Machines
Needle keeps falling
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
May 29, 2012 | Singer 7444 Mechanical Sewing Machine
Singer 7469 will not zigzag
it's possible that a gear or inside cam could be worn or broke, the machine needs to be serviced
Mar 08, 2012 | Singer 7469Q Computerized Sewing Machine
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
I've removed the Timing Belt on my Wifes 3820
adjust your tension, change your needle and adjust also your rotating bar.
Mar 27, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
697 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
