Question about Maxell Computers & Internet
8GB Flash Drive showing only 499MB of memory. How can I fix this?
  • 26 Answers
Delete its partition / partitions using windows disk manager and recreate partition.
Posted on Oct 15, 2013
5 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: sandisk 8gb flash drive
try on other usb port/computer.
Posted on Oct 27, 2008
Damilare
  • 358 Answers
SOURCE: 8gb TDK trans-it flash memory is invisible
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Posted on Nov 19, 2009
  • 2226 Answers
SOURCE: 8mb vs 8gb of space on an 8gb flash drive
try to copy them again to flash drive use a format flash drive first ok
Posted on Mar 28, 2010
bronk50
  • 27725 Answers
SOURCE: how can i solve 8mb vs 8gb of space on an 8gb flash drive
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
hope this helps
Posted on Oct 22, 2012
How can i convert 4GB pendrive to 8GB ...?
There is no way of doing this. If your pen drive is 4GB, that means it has only 4GB of memory chips in it. The only way to get 8GB is to buy an 8GB drive. Do not buy an upgraded (to 8GB) one, as they are lower memory ones that have had the firmware tinkered with to show 8GB, when the actual memory capacity is far less.
18.January.2015
Jan 18, 2015 | SanDisk Electronics - Others
NEED DRIVER FOR 8GB datatraveler 101
Windows has built-in support for usb drives. If your flash drive isn't showing up under "Computer/My Computer" then there is a problem with the flash drive.
Dec 17, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Why only 3GB free on 8GB attache flash drive when everything has been deleted
What operating system are you using it on and what file system did you format the Flash drive with? If you are using an OS that has a file system lower than fat32 or if you formatted it with a file system lower than fat32 then that is why It shows less than 8GB total.
May 22, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I've a 8GB flash drive of hp brand it lose its
You will need to reformat it.
For windows, right click on the drive and hit "Format"
For Mac go to Utilities -> Disk Utility and reformat it from there.
Remember to backup any important files on it first!
Hope this helps!
Jul 19, 2011 | Intel Computers & Internet
Pqi 8gb pendrive showing the error 0x8007045d
It seems that the drive may have corrupt data sectors. Unfortunately this is not generally repairable with flash memory, and you should take the pen drive back and have it replaced under warranty.
Mar 27, 2010 | Electronics - Others
8gb PNY USB2 flash drive refuses FORMAT Can it
use un lockaer it wil shows were the problem is .........................
Sep 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
8gb pny pendrive not working
Try to connect it to another usb . If it still does not see it do check disk with fix errors. I had such a problem many times and usually check disk helps.
Apr 18, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Computers & Internet Logo
73 people viewed this question
Top Maxell Computers & Internet Experts
yobo007
yobo007
Eric
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
