Question about Marvel Appliance Ice Maker
I need to defrost my ice maker. How do I do that?
  • 4 Answers
Marvel usually have an "On" , "Off", and "Clean" selector switch. There are a couple of ways I know of to defrost.
1. Turn the unit off and leave the door wedged open for 24 hours.
2. Get a hose and connect it to another water source, preferably hot water, and melt it off.
Posted on Dec 27, 2013
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
Avanti 1008W
To manually defrost just unplug unit from power outlet for 12 hours,it will automatically defrost.But if these problem is occurring again n again then issue is with defrost assembly parts,the defrost timer,the thermostat and temp sensor in freezer section causing the problem.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Water leaking from bottom of freezer
Its defrost issue.The refrigerator is not defrosting on time,its defrost cycle is running late causing these problem.
Can be faulty defrost system parts or issue with defrost timer.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | General Electric GSH22JFX Side by Side...
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
TFX20JRBKWW how to install heater harness defroster assembly
Defrost heater and thermostat is located behind inside back freezer panel. That panel has to be removed.
Dec 06, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Kenmore Refrigerators
Our ice maker keeps freezing up. I defrost it and it gets stuck again. The drain pipe was also frozen so I just defrosted it but I need to get the ice maker fixed also. Thanks
You need to replace the water valve. The valve is most likely not closing all the way and allowing water to weep into the ice maker and will eventually freeze the supply tube closed.
Jun 11, 2010 | Refrigerators
Ice maker will not make Ice. I have cleaned the
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | Refrigerators
Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
May 19, 2009 | Sub-Zero 561 / F
How do I get water line to ice maker defrosted?
you will have to remove the Ice maker and the use either a hair drier or shop vac the blow air onto the line unit it thaws. Have a Merry Christmas and thanks for using FixYa.
Dec 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Marvel Appliance Ice Maker Logo
142 people viewed this question
Top Marvel Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Marvel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
