Question about Battery Biz Computers & Internet
My 1999 mazda pickup trucks ac went out 2 months ago the pully for the belt on ac fell off now my battery is draining over night ck battery its good could the ac have something to do with it?
Get a shorter belt and bypass the ac compressor
Posted on Oct 15, 2013
Few months ago they disabled the AC and now serp belt shredded again! now they say replace compressor and hook up AC- what??? and $2000
How did they disable the ac if they didn't bypass the pully that is why the belt shredded. The compressor is probably locked up thefore unless the pully is bypassed the belts will continue to shred
Oct 14, 2015 | 2005 Pontiac G6
I have a 2009 Toyota Corolla. About a month ago the alternator went out and I had it replaced. Now there is a rattle coming from the area of the serpentine belt. I replaced belt but the rattle is still...
Have pullies checked out. sounds like one of them may need to be tightend. more than likely it is the tension pully and maybe it needs replaced if the bearing are going out in it. hope this helps and good luck.
Aug 13, 2012 | 2009 Toyota Corolla
How to replace an alternator on mazda 626 1999
OK, This worked well for me. Easier than some solutions I read on the internet.
This method does not require getting under the car.
1. Loosen the 17mm bolt on the belt tensioner pulley.
2. Turn the tension screw (10mm) conuter clockwise to losen the belt.
3. Remove the Serpentine belt.
4. Drain and remove the radiator. Catch the coolant, filter and reuse.
5. Remove the negative battery cable from the battery.
6. Remove the battery cable from the alternator and uclip the control connector.
7. Remove the top alternator support bolt.
8. Losen the bottom alternator support bolt. It will not come out. The support
bracket is a slot, not hole. The alternator bolt and all will slide out of the slot
directly toward the front of the car.
9. Lift the alternator out between the engine and AC condensor.
10. Reverse the procedure to install the new alternator.
Good Luck
Jan 16, 2011 | 1999 Mazda 626
2001 dodge stratus R/T- serpatine belt fell off- why-
correct sounds like the balance pully fell apart, common problem.the outter ring with grooves to hold belt is held together by rubber,wears out and falls apart,must replace that crank pulley,remove center bolt use a puller to remove pully, then install new one and belt.( must be a puller for newer dodges 1999 and up to work.hope this is helpful.
Oct 04, 2009 | 2001 Dodge Stratus
Belt (not ac) is squeaky
The squeeking is most likely coming from your belt's idler pully. They cost around 10 bucks and are attached with one bolt. Kinda hard to get to, so be patient.
Sep 24, 2009 | 1998 Mazda Protege
Replaced the serpentine belt on my car 2001 Ford Escort ZX2 about a month ago and now it fell off and is not worn still new
Did you replace the ideler arm? see if you can wiggle any of the pullys if they move or have end play you will have to fix the pully to get the belt to saty on. be sure belt is on straight.
Aug 27, 2009 | 2001 Ford Escort ZX2
Battery light keeps coming on
it could be just a bad contact at connector,and yes i would ask them to fix it,its atrouble indicator light of the charg. system
Feb 25, 2009 | 1999 Pontiac Sunfire
Belts making noise
Simply check is to replace the serpentine belt tensioner. Looks like this:
http://www.1aauto.com/1A/SerpentineBeltTensioner/Mazda/Pickup/1AEBT00008/975584/1/?utm_source=google_base&utm_medium=cpc&utm_campaign=google_base_api
Another reason you might have alternator going to die. Try to rotate the alternator rotor without belt on it. If you need to use force no free rotation, replace the alternator.
Please kindly let me know if you need more info
Good Luck
Feb 10, 2009 | 1998 Mazda Protege
I have a 99 mazda and i dont remember how the serpateen belts went do you have a diagram i can go by
hi there .there r two belts inner belt goes throw the crank pully ,through tensioner and the alternator .the outer belt belt goes through the crank pully agine to tensioner and the power steering pump .sorry i dont have diagram but thats the way it goes hope it helps do send me the rating thanks
Jan 20, 2009 | 1999 Mazda Millenia
Computers & Internet Logo
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
