Question about Danby Microwave Ovens
My mom put a cup of tea to heat up and after 8 seconds the oven started ssmoking up and a heavy grey smoke was coming out with a horrible toxic smell. What do I do?
  • Danby Master
  • 9,098 Answers
It sounds like the high voltage transformer failed, but it will have to be checked by a knowledgable person.
Posted on Oct 17, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: just bought and installed a
If it's clean inside and behind the stirrer cover, I would suspect a bad magnetron.
If you've had it less than 30 days (or whatever your dealer;'s return period is) I'd take it back.
Otherwise, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Posted on Sep 16, 2008
  • 52 Answers
SOURCE: microwave died and started spewing smoke
Sorry but it sound like a component in the power circuit, transformer/capacitor/diode?.
if you feel capable to do the testing I can guide you
Posted on Feb 23, 2009
co7196
  • 3433 Answers
SOURCE: smoke came out of the door of the microwave oven
Have it replaced.
Posted on Jul 05, 2009
  • 36 Answers
SOURCE: my microwave onen is not heating anything
I would suggest that the overheat stat on the magnetron has blown. If you are happy it's a simple thing to do but just make sure you disconnect from the mains before removing the cover and make sure that the High voltage capacitor is discharged. If you are not sure a qualified service tech will be able to fix this for you at little cost.
Hope this helps
Posted on Jan 07, 2010
Testimonial: "I think you have the right solution for my problem with the microwave. Thanks a lot."
Door will not open
Put right hand on lower section of the door to the right, "crevice" with the left hand press the button to open the door at the same time pull gently to moderate this will release the door in some cases, even if this works you will need someone to check it out.
Apr 04, 2012 | Microwave Ovens
Smoking and electrical smell
OOPS!
Sounds bad!
Remove the power plug & remove the lid!
Remember microwaves are deadly! Never touch! use your eyes only!
Put a 1/2 cup of water in & start. Look if you can see where the smoke comes from. If there is some arching somehhere, you may unplug it & leave it for 1/2 an hour to get rid of lethal high voltages. There may be carbon black at the arching site. You may clean it and if you see any paint damage, cover it with a piece of duck tape. Then try again.
If the smoke comes from the transformer, a square heavy iron box, dump the microvawe.
They are cheaper than the combined cost of the transformer & the labour!
Sep 04, 2011 | Danby DMW1146SS Microwave Oven
Clouds of smoke started coming from the inside of it and we had to put it outside the smoke was coming out of the holes on the inside
It is time to replace the microwave oven, the problem you are describing is one or more issues, the high voltage transformer, high voltage capacitor, the magnetron, and the high voltage diode all play a key roll in generating the high voltage which translates into heating the food. The cost in my view will run high and would be put to better use buying a new microwave oven.
Mar 03, 2011 | Magic Chef MCD1611ST Microwave Oven
Can i make tea in it and how.?
Place you cup of water in the microwave with the tea bag in the cup....The run the microwave for 30 - 1 min. just like you were heating the water...
heatman101
Sep 15, 2010 | Microwave Ovens
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
Microwave Not Working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Jul 09, 2010 | Whirlpool GT4185SK Microwave Oven
Bosch microwave HME9750
the sighn with a spoon inside is to alert you to the dangers of delayed boiling this is were the liquid in a container is heated on the outside quicker than the inside when you remove the liquid and expose it to the ambient air in your kitchen the liquid can boil over scalding your hand it doesnt have anything to do with your friends cup of tea this is pure coincidence the pop is the internal safety fuse blowing will need attn from service tech to sort high voltage safety fuse blowing means inverter or mag faults.
Aug 07, 2008 | Bosch HME9760 Microwave Oven
Purchased GE Microwave, JES1142 in March, 2008. Recently I am having problems when heavy items such as cup of coffee or heavier is placed on turntable. The turntable does not turn and the light does not...
hi nurse becky,
have you put the roller that comes with it?.. normally there is this plastic frame that you place at the bottom of the microwave and it has three rollers that would your turntable motor turning even if you put heavy loads on it. if has one, kindly check each roller if they are turning smoothly.
i hope i was able to help
kindly rate me please
tnx,
drcool
Jul 19, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
