Question about Brother CS-80
My brother machine model # SQ9050 the thread in the bobbin winder jammed and i recd an error E6 now i'm getting an E1 error i'm tring to to get the tangled thread out of the bobin case but no luck can u take the screws out and do this ?
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: machine is telling me E6 error but there is no thread tangled
I am in the middle of fixing this same error. I phoned Brother service in Manchester and they are spot on. Give them a try, they talk you through the problem and suggest things to do to narrow down the cause. Make sure you have the model and serial number as this saves time. In extreem cases you can send your machine to them by parcel post and they will look at it free of charge and then give you an estimate for any repairs needed. If you decide not to go ahead, you can elect to have the machine returned to you for the cost of the postage.
In my case I bought the machine second hand off of E-bay and was getting the dreaded tangle/needle message. I phoned the service department and I was told to thread the machine up and switch on. Then they give you several things to try. Essentially you need to get someone to press the start button while you immediately turn the handwheel forward gently and smoothly.
If this stops the message coming up then you must suspect the motor or its fuse. In my case, it would seem the machine had been dropped as there was a hairline crack in the circuit board which stopped the power getting to the motor.
Posted on Jul 30, 2009
  • 11 Answers
SOURCE: I keep getting an E6 error message - tangled
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Posted on Apr 08, 2010
  • 255 Answers
SOURCE: I have a Brother CS-770.
Hi. It's very likely that the needle is inserted wrong. Take the needle out and make sure that the flat shank of the needle is facing away from you (to the rear of the machine).
Try this and let me know if it helps, ok?
Robbie
Posted on Aug 13, 2010
How can I free up the thread take up lever whcih is seized in my brother bc2100 sewing machine?
Cut the jammed thread away, carefully. It may only need the thread path cleaned of all loose thread bits after you cut off what's gotten jammed up on the lever.
Jun 29, 2014 | Brother Sewing Machines
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
How do I put thread on the bobbin?
Most machines have a bobbin winder on top of the machine under the top cover. The thread may or may not go through the tension above the needle, depending on the machine. There is a small spool holder on top that holds the bobbin and you thread your thread through the bobbin and start the winder. Some machines need the right wheel to be pulled out so the needle does not go up and down, just winds the bobbin. Wind it carefully as if you have loose threads, it can jam the machine and make a thread tangle.
Nov 02, 2009 | Brother LS-1520 Mechanical Sewing Machine
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Aug 24, 2009 | Brother XL-3510 Mechanical Sewing Machine
Brother CS-80 Logo
144 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
