Dtsoftbuscd00 driver It cant read certain cds... such as game cds but if i put a blank cd or some other cd it detects it and would work okay... I'm trying to format the pc but I think the driver wont detect the Windows 7 cd...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Driver's do not factor in on whether a CD/DVD can be seen or not. It is most likely a media issue. Put the Windows 7 CD into another machine and see if that machine can read it.
Posted on Oct 15, 2013
Cpyles07
  • 56 Answers
SOURCE: the motherboard cannot detect the hard drive/ hard disk
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
Posted on May 22, 2008
SOURCE: cd burner not being detected
Try changing out/replacing the EIDE or SATA drive cables.
Posted on Dec 12, 2008
mumma_1
  • 903 Answers
SOURCE: no sound card detected even though I can hear CDs from PC
first check that you are having no problems with your soundcard, go to control panel>system>hardware>device manager and see if there is a yellow exclamtion mark next to the soundcard.. If there is then try updating the drivers for it, or uninstalling it by right clicking it and choose uninstall then reboot the computer, the soundcard will be picked up as new hardware and should be installed again. Before you do this though you need to be sure that you have a pci soundcard actually installed and not an onboard chipset soundcard. If you have an onboard soundcard then it may not be good enough for games to be played. A lot of games require a minimum type of soundcard. Check to see what you have. Go to control panel as explained and write down the model number of your soundcard. Then check the minimum requirements for the game you are trying to play.
Posted on Dec 23, 2008
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
  • 19 Answers
SOURCE: My HP compaq d530 doesn't detect any USB drive.
So we have two problems one your sound is not working and two your usb drive is not detecting any connected devices, correct?
Starting with the sound simply use a friends computer to burn the audio driver onto a cd. Next install the driver on your machine.
Problem two the usb. Remove the flash drive and try plugging in any other usb device such as a printer or camer or cell phone and see if windows says found new hardware. You don't need to install it this will simply tell you if your usb port is functioning or has a problem. if you do get a found new hardware message then your usb port is functioning and may only have a problem seeing your flash drive. Try uninstalling the usb port in System Properties. Right click on My Computer then left click on Properties. Now click on the Hardware tab. Now click on Device manager. Now go to the bottom where the usb devices are and uninstall all usb devices and when your done restart the machine. See if you can use your flash drive now. Other wise check your bios settings for the usb devices to see that they are infact set correctly and if you cant do this take it to your local pc repair shop and they can do this for you.
Hope this helps.
Posted on Sep 24, 2009
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
The pc won't burn cd's seems like it doesn't recognize cds or dvds
Does the cd/dvd drive read cds? This is a good test to ensure that the drive is functional.
Sometimes, generic cd/dvd burners do not recognize certain types of blank discs. Try another type of
brand blank discs, it should work.
May 01, 2011 | E-Machines eMachines Desktop PC
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
DVD is reading, Not reading some CDs (CD-R Which is written)
Hello,have you checked what format is the cd? your burner supports only CD-R and not CD+R,also check the cd if is dirty or scratched!
Jan 18, 2010 | LG GWA-4164B DVD±RW Burner
My GH20NS10 LG CD/DVD burner won't detect blank CD-R
Please e-mail me with the specs of your computer at mr.a.c.stopher@googlemail.com and i will help you and might solve your problem for you.
Jan 04, 2010 | Computers & Internet
I put a cd that my friend made for me and the radio worked for reading i saw numbers but nithing was playing try to take it out and everything went blank now i just have a buzzing sound and cant do...
Assuming other CDs work, it sounds like your friend recorded the CD in the wrong format, probably digital format or your CD player cannot read the CDR. Not all CDRs can be read by all CD players regardless of what others may tell you.
Good Luck,
Gilsh
Nov 26, 2009 | Car Audio & Video
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Its exactly like that.
it just means that the disc has no media that it can read, or that the media is in a folder, or it is a blank disc.
Aug 08, 2009 | Microsoft Xbox 360 Console
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
