Question about Whirlpool Refrigerators
Icing up along the top of whirlpool ARG979/R integrated Fridge
  • dk81a Oct 17, 2013
    This mode log fridge is an integrated one ..frost free !!...icing starts the moment the fridge is switched back on after the fridge has been diced and cleaned. Icing starts at the top right hand rear of the unit and gradually expands along the back increasing in thickness to approx 25mm after say 2 weeks.
Integrated fridge door keeps springing open. what is causing this?
the magnetic seal along the door may have gone bad. or bad worn out door seals not keeping or creating the pressure needed to cling door shut
Feb 19, 2015 | Whirlpool Refrigerators
Refrigator icing at bottom then leaking
bad door seals causing condensation and water accumilates in fridge
Aug 25, 2014 | Whirlpool Refrigerators
Water keeps draining into the refrigerator and icing up. The freezer also has water icing up on the bottom panel.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Whirlpool (ET8FTEXSQ) Top Freezer...
Whirlpool refrigerator type 21TFA refrigerator won't cool - air vent in freezer keeps icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My top freezer Whirlpool refrigerator (ice maker not hooked up) is getting water on top shelf and icing up. Also, water in crisper drawers.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 28, 2010 | Whirlpool Refrigerators
WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Oct 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ARC7470AL FRIDGE FREEZER
you have one of three problems and only one problem
the defrost timer is bad
the defrost heater is bad
the defrost thermastat is bad
only one of the above is the problem but no way to know without checking each part with and ohm meter
May 07, 2008 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
