Epson perfection v30
My scanner power light flashes for split second when I plug it in but will not power up.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 156 Answers
Sounds like a Faulty printer......could be the power source or power supply but I would consider looking into a new printer
Posted on Oct 15, 2013
4 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: I have lost the power cable for my Epson perfection 3490 -
Hi Dave!
Go to a good elecronic store and buy a power cord.
Juste be sure that you have the info about the cord you lost.
You will find that info here:
http://files.support.epson.com/pdf/pr349p/pr349ppg.pdf
Just make sure that the voltage and the amphere is correct.
Any good elecrtonic store have replacement cords stored.
Good luck to you
Nic
Posted on Feb 05, 2009
Van_Fanel
  • 25 Answers
SOURCE: Computer can't connect to scanner
If you are using Win XP there's another way of testing it with your computer for to check if your scanner is damaged or just a simple
software issue:
Usually for Epson it came with an Application called "Epson Scan"
> with the scanner connected to your Computer try to scan using a diff Application like PhotoShop or MS Paint
> to scan using Paint
Click on Start / All Programs / Accessories ( click and open "Paint" )
> from Paint click on File / and click "From Scanner or Camera" and it will open a scanner wizard., just follow the step by step procedure on how to scan.
note: if you have a diff. imaging devices ( like web cam ) it may ask you which one to use., make sure to select your scanner.
> if it can acquire an image using paint or diff application., there's no issue with the scanner unit.
> if it cannot acquire an image using paint or diff application., your scanner is broken / damaged.
To fix the issue with Epson Scan
> Uninstall "Epson Scan" from Control Panel / Add or Remove Programs / disconnect the scanner unit "USB cable"
> Control Panel / Administrative tools / Services ( look for Windows Image Acquisition < WIA > click on it and restart the service.
> Close all the windows and restart your computer.
Download the Twain Driver from the Epson Website
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88043&prodoid=63070037&infoType=Downloads&platform=Windows
downlad > TWAIN Driver and EPSON Scan Utility v3.12A
epson12526.exe )
note: if you don't have internet you can use the cd that came with scanner...
> after it is installed your computer might restart and then:
> click on Start ( right click on My Computer / left click on Properties ) on the Properties window click on Hardware Tab / Device Manager / on the device manager window look for "Imaging"
under Imaging look for your scanner ( right click on it and click on update driver., select this time only hit next / select Install the software automatically ( recommended ) hit next and it will update your scanner driver.
> Close all windows and Launch Epson Scan
Posted on Apr 18, 2009
SOURCE: My Epson Perfection 4990 indicator light is
I had the same problem and first checked the instructions in the Epson manual on the red flashing problem, read the following pdfs: Indicator light or problems
I saw the fluorescent lamp come on for a second before the indicator light started to flash red, so I knew that the lamp was ok and did not need to be replaced. Try this turn off the scanner and try unplugging the transparency lid from the back of the scanner, turn on the scanner and see if the light goes back to green. My issue turned out the be the mechanism inside the transparency lid, I kind of heard an awkward noise when I turned on the scanner, but thought it was coming from the base, I rlocked and unlocked the transportaion lock on both the base and lid, to see if that would fix it but it turned out it was coming from the lid, where there is also moving parts inside using a belt and wheels. On the end wheel closest to the front, the 2 little plastic pegs that hold down the square metal plate with wheel broke off, I could hear them inside when I lightly shook the lid, anyways I opened up the lid by removing the 5 screws and you need a screwdriver to put in each of the little openings around the edge to pry open the lid. I removed the belt and metal plate, watch out there is a spring attached to it, don;t forget how this part works when you put it back on, I found both of the little broken pegs and glued them back on with a strong plastic epoxy glue that I bought at Ace Hardware, I let that dry for 24 hours and then put the metal plate and wheel on then put the belt around the wheel, and now everything works fine.
Posted on Aug 02, 2009
I want a owners manual so I can figure out how to use my Epson Perfection V30 scanner. Can you help?
You can download the manual at http://www.epson.com/support
If you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 24, 2011 | Office Equipment & Supplies
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
Dec 24, 2009 | Epson Perfection V500 Flatbed Scanner
My epson 3490 photo scanner isn't working theres a red light on the front of the scanner which is flashing
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
After trying these solutions, unplug the scanner to turn it off, then plug it back in.
Sep 30, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Epson 2400 scanner
it's probably locked, look for a switch either on the bottom or on the side.
Sep 09, 2009 | Epson Perfection 2400 Photo Flatbed...
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
Jul 27, 2009 | Epson Perfection 2400 Photo Flatbed...
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
Epson perfection v100 won't start
do you have a meter- digital?
measure prior to scan ~14.5vDc when it fails check again
could be the power pack or the small control logic brd near the hinges/buttons
might have to reseat the connector
Mar 01, 2009 | Epson Perfection V100 Flatbed Scanner
Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Jan 04, 2008 | Epson 2580 Perfection Photo Scanner
52 people viewed this question
k24674
