Question about Xerox Office Equipment & Supplies
Xerox WC 7655 error 09.548 - Xerox Office Equipment & Supplies
5 Suggested Answers
  • 12 Answers
SOURCE: Error on wc 7120 xerox 124-315
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
hen look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Posted on Mar 13, 2013
  • 77 Answers
SOURCE: xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Posted on May 29, 2013
cbrtechso88011
  • 260 Answers
SOURCE: xerox WC 7132 printer error code 016-601 error and
  1. Click on the "Configuration" tab
  2. Choose the account mode to "User"
  3. Click on "Detailed User Settings"
  4. Change the password details as per instructions from your printer administrator
cFor more help visit cbrtechsolutions
Posted on Nov 08, 2015
  • 44161 Answers
SOURCE: Hello I have a Xerox wc 7655,it displays an error "image disc is offline" and stops printing.I don't know how to go about this error. I need some help please.
Read the top line where it says "Xerox Service must be called."
Posted on Dec 09, 2016
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Have a Xerox WorkCentre 7655 showing system fault nodity system adminirattor
Notify the system administrator, unless, of course you are that individual.
Jun 12, 2013 | Xerox WorkCentre 7665 Copier
Xerox 7655 can it borderless print
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
