Question about Health & Beauty
My TFY scale will not weigh. It shows the Po , gender, age, everything else but will not weigh It goes to 00 and closes. What ca I do? I put in new batteries.
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
  • 279 Answers
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Posted on Jan 17, 2010
  • 39 Answers
SOURCE: Model WW78 does not let me put other persons
Here are the instructions, have you seen them before.
http://docs.google.com/fileview?id=0B_umxTtnIOPDYmI4ZWZiZjctOWZjOS00ZjQ0LTlkYzEtYzkwZmQ2Y2Y5ZWEx&hl=en
Posted on Feb 02, 2010
  • 5 Answers
SOURCE: scales not working properly- weighing too light
scale may need to be calibrated or you may have something causing the scale to be unstable or something could be binding
Posted on Mar 13, 2010
SOURCE: When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Posted on Jun 17, 2010
I can't set the body fat on my Health o meter and it gives me an E every time I try to weigh myself.
The Error message may be indicative of a defect in the scale but could appear because the parameters you enter cannot be processed. Try again to get a manual by Googling (Health o meter)(BFM688D-60)(manual) without parens.
Jan 18, 2017 | The Health & Beauty
I have bathroom scale model ww707y.
http://www.conair.com/instruction_booklets/06AD15148%20ww33_ww35%20IB%20mechx1a.pdf
Dec 20, 2015 | Crafts & Hobbies
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
Jan 16, 2010 | Jobar International Idea Works Wireless...
No instructions. how do i set it up and what does
P zero to P 9 is just a user number to set it up... Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 is fine).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Oct 17, 2009 | Taylor 5757 Digital Glass Body Fat Scale
I need to set up my health-o-meter BFM920 digital scale and body fat, but I don't have the manual.
Hold down the button for the person you want to setup (1 or 2) until the displays shows the height and the number of feet start blinking. Use the up and down arrows to change the numbers and the Set button to move to inches, age and gender.
Oct 06, 2009 | Health-O-Meter Health & Beauty
SCALE SETTINGS
To change the height/weight/age, hold the user # you want to change it for and the set/save button at the same time for a few seconds.
I am #2, so I hold the 2 button and set/save. Then you can use scroll to change the numbers/options, and set when you have properly set the digit.
First it does height, then age, then gender, then if you want a goal, and then what that goal is.
Apr 09, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Health & Beauty Logo
18 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
