Question about Garden
What is the fuel mix for a homelite mp 88 - Garden
3 Suggested Answers
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
Posted on May 04, 2010
  • 221 Answers
SOURCE: what is the fuel mix ratio
50 to 1. try to find non ethanol fuel to run in it also.
Posted on May 17, 2010
How to mix fuel and oil
Page 14 here
http://www.manualslib.com/manual/453515/Homelite-Ranger-Ut10926.html?page=14#manual
May 27, 2016 | Homelite Garden
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I just purchase a homelite leafblower ut 09510 175mph, do i need to mix oil and gas for fuel?
Yes, you will need to mix up some fuel with two cycle oil. See your owners manual for the proper mix ratio. Keep this fuel in separate container from your lawn mower gas.
Sep 04, 2011 | Homelite Garden
I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
I have recently obtained a Homelite "zip start" trim n edge string trimmer. What fuel mixture is recommended for it?
Modern Homelite equipment uses a 50;1 fuel mixture. That is 2.6 ounces of 2 cycle mix to 1 gallon (U.S.) of gasoline. I highly recommend to use a quality 2 cycle oil that is designed for lawn equipment. I also recommend to use a mix that contains fuel stabilizer. This will usually be in a 3.2 ounce bottle.
Always use fresh fuel, it prevents problems in your equipment.
Nov 29, 2010 | Homelite Consumer Products MightyLite...
Need to know the fuel and oil mix on a homelite 330 chainsaw
The fuel, oil mix for homelite chinsaws is 32:1. Hope this helps.
Sep 26, 2010 | Homelite ZR10926 16" Chain Saw
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
