Question about Refrigerators
Water is leaking out back of refrigerator when we use the icemaker to get water.
  • 113 Answers
Check all lines and be sure theyre connected properly
Posted on Apr 24, 2009
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE PSS23mstcss Icemaker not working
icemaker will need replaced, < only other concern with description is water dripping> would not address this unless problem did not go away after replacing icemaker, < could be leaking water valve>.
Apr 23, 2009 | Refrigerators
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Nov 04, 2008 | Frigidaire FRS26ZSG
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
My Ice maker stopped working (no water for ice) I replaced the water supply solenoid and plugged it back in. Ever thing worked fine except when the water valve cycled open. Water began leaking from the...
Yes, the short tube that goes from the back of the refrigerator to the icemaker can freeze up solid preventing any more water to pass thru. this is caused by a bad water valve that is slowly leaking water to the icemaker.
Jul 05, 2008 | Refrigerators
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
