Question about Kodak Office Equipment & Supplies
LPT1 error What does error Where:LPT1 mean - please?
    Problem Solver:
  • 6 Answers
LPT1 is probably your default printer port assigment. I would re-install the factory software to see if that clears it up. Your printer probably came with CD - use it to reinstall the printer.
Posted on Oct 15, 2013
What does Communication Error mean?
I am guessing that you are using Windows 7. If so go to Control panel 'Hardware and Sound' Printers and select Remove a Printer. You may then unplug the printer usb connection and restart your computer. When the computer has restarted , you may go to the link below to download the most current drivers and install them .
Do not plug in the usb connection until you are told to do so. Also, the printer may select a default connection to LPT1 , which is a parallel port connection (apparently this printer likes to do so , and this will give you your "communication error" ). If it does, go to printers in control panel (see above) , right click on the icon for your printer , select "properties" , and left click on the " ports " tab. Make sure that the port selected is USB001 or similar and NOT LPT1.
Epson Stylus Photo R280 Ink Jet Printer
Aug 16, 2014 | Epson Stylus Photo R280 Series
Error LPT1
This is the communication port with which the cable plugs into instead of using for example an ethernet port. Not sure what you are meaning with just the reference LPT1 but this is simpl;y the port the cable plugs into
Sep 13, 2011 | HP LaserJet 4 plus Printer
Lost communication with computer, neither USB or LPT1 works. Printer stopped mid-job after working well for 3 years
please check the printer statues ..after switch on the printer its comes to the ready condition ( ready is on ) .. second thing please check the printer driver in control panel ( printer and faxes ) it should be ready .... one connect the printer to the pc and check it detecting or what if its detecting please reinstall the printer driver and check .......... if its not detecting its may have problem with the printer connector or main board ............. please reinstall the printer driver and try ....... if the printer is working means it will help you .....if you are getting any error while giving please post the error .......
Jan 04, 2010 | HP DeskJet 1220c InkJet Printer
Out of paper
in printer properties select the paper source and size correctly.
Feb 20, 2009 | Toshiba e-Studio163 Copier
PrinteInkjet download error
Check the printer ports, it is probably that your printer is connected to a wrong port. You have to go to printer properties and then to "Ports" If your printer is connected via LPT1 this port must be selected or if your printer is connected via USB port the "Virtual USB port" must be selected.
Jan 06, 2009 | Lexmark JetPrinter Z25 InkJet Color...
LPT1 not working
Hi looking at your description it seems more like a drive error as a opposed to lpt1 problem, I've never known a lpt1 port to stop boot.
Sata drives are notorious for bad connections, could it be that the connections to your drive have worked loose?
I hope this helps, if not please let me know thanks.
Jan 05, 2009 | IBM ThinkPad T60 Notebook
Print not comming
my printer hp 2300 print only on page
Sep 17, 2008 | HP LaserJet 2300 Printer
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
MY Epson Stylus C60 wont print
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
Printer time out error!!????
is your printer connected with a serial cable, if so, you may have to install the printer and software again, but if you are connected via usb and this is the given error then there is a connection fault as, you may already know that LPT1 is not a usb connection but serial cable.
Apr 29, 2007 | Canon S400 InkJet Printer
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
