Question about Stanley Tools & Hardware - Others
How do I change the sanding belt on a Stanley H31A sander. I can't figure out how to release the tension to put on a new belt
cloe2594
  • 29 Answers
SOURCE: Dremel belt/disc sander
see the manual
Posted on Nov 06, 2008
mikeymiddles
  • 58 Answers
SOURCE: Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Jun 13, 2011 | Black & Decker Garden
I've lost the manual and I can't remember how to change the sand paper belt. There is a lever on the side which I've sort of tried but don't want to pull it too much incase its the wrong thing...
Pull that lever all the way out, you should see the front wheel pull back and the tension on the belt should release so you can pull the old belt off and put the new one on. Center the new belt on each wheel then push the lever back down. When you first turn the sander on check that the belt is tracking in the center of the wheels. Turn the tracking knob to adjust if necessary.
Sep 08, 2010 | Tools & Hardware - Others
How do I change the sanding belt on my 7447 belt sander
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
is it a B & D 3x21 belt saNDER. iF SO, PUST THE REAR DRIVE WHEEL FORWARD UNTIL IT CATCHES, PUT THE SANDING BELT ON, THEN RELEASE THE CATCH WITH A LONG SCREWDRIVER ANDIT WILL SNAP BACK INTO PLACE. hOPE THIS HELPS
Aug 18, 2010 | Tools & Hardware - Others
How to replace sanding belt
Usually there is a lever which when released allows the two rollers to go closer together, thus releasing the tension on the belt. You can then slide the belt off the machine and put on the new one before re-tensioning using the lever. If this helps, please rate me! :)
Jul 17, 2010 | Black & Decker BR300 3''x18'' Belt Sander
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Loose sanding belt
CHANGING DRIVE BELT
  Remove the cover.
the motor pulley.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
173 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
