Question about Nintendo 3ds Handheld Game Console- Cosmo Black for DS
My 3ds wont turn on, i push the power button but the screens dont light up only the blue light. After 20 seconds it makes a popping sound then shuts off.
    Scholar:
  • 54 Answers
If it is the 3ds (which is different from the ds lite and dsi), then see which screen flashes before the popping sound. The one that flash is working. The other that stays dark is not getting power. The fact that you hear the popping sound tells you that the speakers are working.
If the bottom lcd flashes, then issue is related to the top lcd. The top lcd is connected to 3d/speaker cable. That means the top lcd may be fine but the issue is with the 3d cable. Open the back of the 3ds and check the connection 3d cable to the motherboard. (carefully because the screws are thin and can be stripped). Then open the top half (carefully because the black cover is glue on to access the screws to remove the other cover. Check the top lcd connections to the other ribbon. If they are loose, then refasten them. This is the best option because it is simple repair. Just be careful not to bend the pins. If you see any damage (i.e. tears, broken clasps), then those parts will need to be replaced. It is easier to replace the cable or the lcd, motherboard replacement is not enjoyable.
Posted on Dec 02, 2014
  • 37 Answers
First check the battery and see if it's not the problem. If you can borrow a known working battery from friend etc. and it still does not power on it's probably a microfuse that's blown and you should have it repaired by a professional
Posted on Oct 16, 2013
Testimonial: "its not the battery i think it might be the top screen"
SOURCE: 3ds wont turn on
Try holding down the power button for a minute and this should turn it off so the blue light gos off, then you can press the button again it should come on properly.
Posted on Jul 13, 2013
SOURCE: My dsi wont turn on when i press the power button
You have a bad top screen, have the top screen replaced.
Posted on Nov 18, 2010
  • 69 Answers
SOURCE: NDS Lite dont run or only completely opened
most likely its the top screen ribbon.Because when you open the ds all the way it might push the ribbon in just enough to be read but when not open it cant read the top screen and it will shut down.I have instructions on how to change a top screen you can use them to put the ribbon back in. the only difference is you don't need to unplug the white and black wires.First you need a tri wing screwdriver and a cross screwdriver.You can get both on ebay.Then their are seven screws four tri wing and three cross.You will need to pry the back off be very careful.Start on the side that doesn't have the on off switch and work your way around.Once you have the back off unscrew the two cross screws that hold the logic board on.Then unplug the white and black wifi2_bing.gif and mic wires they snap on and off.Then flip the logic board over by pushing the bottom screen out.On the other side is where the ribbon for the top screen is.To get the hinge apart their are two more cross screws in the top left corner take them out that releases the hinge.very carefully roll the ribbon so you can get it through the metal ring and the wires pull the wires first.to get the top apart the four cross screws are above and below the speakers2_bing.gif under those small squares.A needle will get them out easily .Once you get the screws out then slid the back of the top up 1/8 of an inch then pull the back off carefully.You need to push the screen out and unsolder the speaker wires or use new ones.Make sure when putting it back together you roll the new ribbon the right way look at the old one to find out .Getting the old ribbon out and the new one in is a little difficult so take it all apart first and get the wires out then the ribbon and put the ribbon in first.
Posted on Mar 09, 2010
localwonder
  • 6784 Answers
SOURCE: wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Posted on Jul 28, 2009
  • 10 Answers
SOURCE: wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Posted on Jun 14, 2009
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
3ds wont turn on
Jul 04, 2012 | Nintendo 3ds Handheld Game Console- Cosmo...
Touch screen stuck 3ds wont turn off
If the 3DS ever freezes up on you (it's happened to me a few times now), press and hold the power button for about 10-15 seconds, it should force it to cut the power entirely without requiring you to touch the touchscreen.
Aug 22, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
I turn it on and it makes the sounds of starting, no screen, it ran all night, I could hear that. now it just wont turn on the screen. Have I pushed a button or something wrong.
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 11, 2010 | HP Computers & Internet
My controls wont work
Hi, Sounds like you need to check the sensor bar. Make sure it is plugged in or if you have a remote sensor bar check it's batteries. If this doesn't work you can clear the console sync info by turning off the console power, unplug the console for a few seconds, plug it back in and turn the power back on. When you get the Health and Safety screen, press and hold the console synchro button for 15 seconds. Now resync your wimotes by using the red buttons in the remote battery area rather than the screen sync. If you need more help let me know as there are other things like a stuck button on a controller to look for. Good luck!
Jan 28, 2009 | Nintendo Wii Console
I replaced the burnt out lamp,not working !!!
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Nintendo 3ds Handheld Game Console- Cosmo Black for DS Logo
362 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
