Question about Panasonic SC-AK330 Shelf System
Panasonic SC-AK 330
When I turn unit on, it signed no makes a clicking sound as it was trying to connecting, but no power. I opened the unit to check the fuse, (fuse was not blown) but I replaced anyway. same problem
please advise signed
No Power No Party
  • 130 Answers
SOURCE: Panasonic SC-PM08 shuts down error F74
Would be cool if that display means you have #74 fuse blown. Maybe its for the amp output to the speakers? have you tried the speakers on another system? could they be blown? Is there anything in the manual about the error?
Posted on Apr 10, 2006
snakehead
  • 1074 Answers
SOURCE: Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Posted on Apr 06, 2007
  • 4234 Answers
SOURCE: I have a CD STEREO SYSTEM SC-AK640
Usually the problem here is the output amp pac(s). Without takeing a few measurements, I can't tell you which ones. Also, can you please check the model number, I can't find a listing for the one you posted.
Thanks,
Dan
Posted on Apr 14, 2008
dunnbiker
  • 8546 Answers
SOURCE: MY MAIN UNIT FOR A PANASONIC SC-AK29 ITS
I found one complete unit on Craigslist in Fishkill, NY for $35. perhaps you can search the area closer to yourself and find one.
There are none at this time on eBay but you never know when one might appear.
http://hudsonvalley.craigslist.org/ele/2115301923.html
Posted on Dec 28, 2010
  • 910 Answers
SOURCE: Panasonic SC-HC3 micro system .
The least you should do is with the unit unplugged, remove the rear cover and check for an internal fuse. It should be somewhere near where the mains cable plugs in.
Posted on Jun 28, 2011
I have Panasonic SC-HTB500 Sound bar, It is not power on. When i Press power on buttion.it is come little realy switch click,and again click.l checked inside not any thing i can see,
Unplug it from its power source - whether it plugs directly into a wall outlet or into a power outlet on another component (TV, amplifier, etc.) Simply wait 2-3 minutes and plug it back in. Sometimes, electronic units just get "stuck" and will recycle if unplugged for a while, then plugged in again. This happens with TiVo every year or so. If that doesn't work, I don't know unless you want to contact Panasonic. Is there a reset button on the unit. If so, try that.
Aug 13, 2016 | Panasonic Sc Htb500 Sound Bar Home Theater...
Panasonic Sa-Ak 330 neither tape deck will open, makes clicking sound
It is a mechanical fault. The mechanism should have to be repaired. Contact any experienced technician.
Jun 17, 2012 | Audio Players & Recorders
UNIT WILL NOT POWER UP / NO FROUNT LIGHT / NO RELAY CLICK / HAVE CHANGED POWER SUPPLY BOARD ALREADY
if you change power supply then make sure it working check for stby 5 volts and check volts on power switch if voltage are there then power supply may be good. try to disconnect connector or sc board and ss boards. both on side of the tv then turn on the tv it will give you click turn on tv you should hear somr sound if not then your main board is defective if tv come on when disconnect the ss or sc boards then one of them boards are defective
Dec 03, 2011 | Panasonic TH-42PD60U Television
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
My Panasonic SA-HT75 clicks off seconds after I turn it on. Even got a F61 code.
Open the unit and clean/replace the fan.
If it doesn't turn when you power it on after cleaning it, put some oil on its bearing sleeve.
Never power on this device while speakers are not connected!
Hope this solves your problem!
Feb 23, 2011 | Panasonic SC-HT75 System
Unit will not turn on.
I think we have the same problem only mine is flashes an F61 on the display then shuts itself off.
Jan 02, 2007 | Panasonic SC-HT650 System
Panasonic SC-AK330 Shelf System Logo
120 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
